4 to 5 lug and rear disk
whats up guys and girls new to the site i have a 88 mustang lx i want to convert my 4 lug to 5 and my rear drum to disk....what i have is a complete rear end out of a 87 Lincoln mark vii ....can i have the axles shortened and use all the brake hardware to make this work ???? also im trying to use 18" billets wheels 5 lug i dont think i can use the front rotors from the Lincoln mark because the dust cap will stick out to far dose anyone know if this is the case
HELP |
might can use a rear from a sn95. my 94 has disks.
Powerdyne supercharger Ebrock perf upper/lower intake Steeda 18 cam GT-40 heads MSD Ignition All forged bottom end BBK headers 3:73 rear end T-5 Manual Trans
take some time and look around through previous threads...theres been more than one already about the change over.
Welcome to the site....did you sign in?
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
doorvip
I am using the axles out of the same Lincoln without modification to the axle itself, although there are other modifications you will have to consider in this project, primarly being the diffrence in the brake cable and the readjustment rear/front proportioning valve below the master cylinder among other things. Basicly you are attempting to do the same thing the original SVO Team did in the "eighties" with the "famed" 84-86 SVO. The brakes off the SVO's are in fact the same as the Lincoln Mark VII.... As far as the wheels are concerned I am currently using the "93" 17" Cobra R rims with 245/45ZR17 tires on both front and back !!! NOTE: REPLACE FRONT FENDERS FOR THE LARGER OPENING 90-93 FENDERS.. |
Threads Similar to: 4 to 5 lug and rear disk
| 6 disk acting up | exrider23 | Audio/Video | 35 | September 7th, 2007 03:15 PM |
| puck or disk | angermgt | 5.0 Mustangs | 0 | June 9th, 2007 09:48 PM |
| rear disk upgrade in fox ? | 92_fox | 5.0 Mustangs | 0 | December 15th, 2006 08:51 PM |
| 4 To 5 Lug Convertion And Rear Disk | doorvip | 5.0 Mustangs | 0 | November 16th, 2006 06:11 PM |
