Good or bad ???
Old August 3rd, 2008, 05:22 PM   #1
1989 LX coupe 5.0L
89lx is on a distinguished road
Good or bad ???
ok i just had my car on the dyno and i had 166 Rwhp and 220 ftlbs power peaked at 3500 does that sound right...
cars sd not maf, sea level, 235 60 15's tire size
Mod list ..
BBK shorty headers
BBK off road H-Pipe
Flow Master cat back
355 gears out back
Upgraded engine and trans mounts
Goodyear rad hoses
Ford Motorsport 9mm wires
Ford Motorsport Cap + Button
Ford racing A/C eliminator
Professional Products harmonic balancer + spacer
Cold air intake
elc fan
Fidanza aluminum flywheel
Ford motorsport aluminum driveshaft
BBK underdrives
Old August 3rd, 2008, 05:30 PM   #2
1992 Lx
11.39@119.24
sounds pretty dam low to me, especially the tq
Old August 3rd, 2008, 05:32 PM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
yea there is something wrong there man
Old August 3rd, 2008, 05:32 PM   #4
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
that doesn't sound right to me.. some other guy had his stock 5.0 dynoed and it was like 192rwhp and i forgot what the torque was
MM 1 am boner crew
Cars and mod list in garage
i like veiny meat sliding between my buttcheeks
Old August 3rd, 2008, 05:44 PM   #5
1992 Lx
11.39@119.24
it was 91cobra5.0 and he put down
91 mustang
266 ftlbs 191 hp (15.138 @92.91)
almost stock and alot higher elevation, and i doubt his power topped off at 3500
Old August 3rd, 2008, 07:23 PM   #6
shadowgames81's Avatar
87 Coupe
shadowgames81 will become famous soon enough
stock at the motor should be around 215-225 and w/ that list of mods obviously more. I think that is quite a bit lower than I'd expect.
Eats rice daily
Old August 3rd, 2008, 07:28 PM   #7
1992 Lx
11.39@119.24
it was on a dyno, its not gona read 215-225 at the wheels
Old August 3rd, 2008, 07:29 PM   #8
87 Coupe
I know that.....I said at the motor didn't I??? W/ the parasitic loss through the drivetrain it should still be more.
Eats rice daily
Old August 3rd, 2008, 07:35 PM   #9
1989 LX coupe 5.0L
any ideas where i am losing the power?
Old August 3rd, 2008, 07:43 PM   #10
87 Coupe
compression check??
Eats rice daily
Old August 3rd, 2008, 07:43 PM   #11
JBIGBOOTSY's Avatar
1990 LX hatch
It depends on the chasis dyno, take it somewhere else and the power may go up.
Old August 3rd, 2008, 10:15 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Mod list ..
BBK shorty headers
BBK off road H-Pipe
355 gears out back
Goodyear rad hoses
Cold air intake
elc fan
BBK underdrives
That is really low.
Old August 3rd, 2008, 10:28 PM   #13
s3c2n01 is on a distinguished road
man you need to park that thing and find out where your problem is.
there is something not working there.
4.6 2V PI HEADS,PI CAMS,COMP SPRINGS,PI INTAKE,03 COBRA CRANK,PISTONS,5140 S/F RODS, VORTECH S TRIM 6/9PSI 3.73 60 LBS INJECTORS,90 MM MAF, SCT CUSTOM TUNE.
Old August 3rd, 2008, 10:32 PM   #14
it has more then that stock. there is a problem some where.
Old August 3rd, 2008, 10:33 PM   #15
91cobra5.0's Avatar
98 Cobra
91 mustang
yea but im at like 6000 ft ABOVE sea level
Old August 4th, 2008, 06:32 AM   #16
1989 LX coupe 5.0L
what kinda numbers should i be getting?
Old August 4th, 2008, 05:56 PM   #17
1989 LX coupe 5.0L
i know its not the problem but i changed the fuel filter it was pretty choked up tomorrow night if all goes well i am going to check the plugs and compression, fuel pressure and clean the injectors, and make sure my tps is reading right. any other things i should check?
Old August 4th, 2008, 07:51 PM   #18
95StangMX's Avatar
95 Mustang GT
I am not sure on the HP but 3500 seems really low for peak.....unless its diesel...j/k ....I would say maybe a compression test is needed...and maybe check the timing ....but if they dynoed it they should have checked that i would think....who knows....
Old August 4th, 2008, 07:53 PM   #19
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
In the area of 200hp at the wheels for the modifications you have. Possibly a bit higher or lower depending on the type of dyno, weather conditions, etc.
Old August 9th, 2008, 06:25 PM   #20
1989 LX coupe 5.0L
i checked the fuel pressure its 32 psi running, compression is 150psi on all cyl's, cleaned the injectors, changed the fuel filter, found one bad plug, checked timing. where do i go now ? it had code 81, 82, 85, 84.... i have the egr deleted.
Threads Similar to: Good or bad ???
the good the bad and the ugly whitemustang02 The Clubhouse 11 May 22nd, 2008 07:37 PM
nitrous is it bad or good jrock 99-04 16 March 25th, 2008 11:05 PM
good.. bad.. ugly..? Squints 5.0 Mustangs 29 March 24th, 2008 07:16 PM
good or bad idea? artisan00 V6 Mustangs 10 February 10th, 2006 01:23 PM
