Took My Car To The Track!
Old August 3rd, 2008, 11:54 PM   #1
blue90lx's Avatar
90 lx hatch
12.83@105
blue90lx is on a distinguished road
Send a message via AIM to blue90lx
Well i finally took my car to the track, been waiting for 2 years, since all the body work. But anyways here are the times:
reaction-.604
60'-1.795
330-5.498
1/8-8.544
mph-81.27
1/4-13.354
mph-101.62
That's a diff. compared to the last time i took it to the track. It ran a 14.2 at 100mph. I only got one pass to many people on a Friday nite tnt. I had to let off when i hit second the car went towards the wall. So i'm thinking it may have a little more in it. But i was real happy with what it ran. Also i had 10lbs of tire pressure in my et streets, the car was all over the place, i was thinking of running 15lbs next time to see if it will eliminate that.
to many parts and money to be so slow
Old August 4th, 2008, 12:06 AM   #2
blue90lx's Avatar
90 lx hatch
12.83@105
Oh and mod lists consist of:
Stock e-7 heads (no port work)
Trickflow u/l intake
bbk long tube headers
bbk x-pipe
70mm tb
bbk under drive pullies
b-303 cam and 1.7 roller rocker
tremec 3550 spec stage 2 clutch pp
frpp alum. drive shaft
3:73 gears moser axels
lakewood traction action lift bars and southside machine uppers
eibach drag launch spring only in the rear and lake wood 50/50 shocks
m/t et streets
alum rad. and electric fan
Old August 4th, 2008, 06:50 AM   #3
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
i found that @ 12 psi worked pretty good for me when i was running et streets , any less and i think the tire cupped
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old August 4th, 2008, 07:12 AM   #4
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Awesome work on stock heads. Go get some heads and break 12's my man.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old August 4th, 2008, 10:42 AM   #5
blue90lx's Avatar
90 lx hatch
12.83@105
Cool, thanx for the info man
Old August 4th, 2008, 11:13 AM   #6
ryans88gt's Avatar
nice times.
Do you have tubes and screws, cause you need them to run tire pressures that low.
Old August 4th, 2008, 12:07 PM   #7
blue90lx's Avatar
90 lx hatch
12.83@105
Originally Posted by ryans88gt View Post
nice times.
No, that's why i'm not going to run that low of tire pressure , that and cause it was all over the place
Old August 4th, 2008, 03:51 PM   #8
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
not to bad, go up on the tire pressure and it should be a little more stable, also you got a good set up, if i were you i would look for a good set of heads to go with the rest of it
Threads Similar to: Took My Car To The Track!
Ran my slow car at the track! Need advice gotn20 5.0 Mustangs 21 July 27th, 2008 06:25 PM
E3sean Needs To Get His Car To The Track Fund. e3sean The Clubhouse 12 April 28th, 2008 12:36 PM
First time with the new car at the track. ryans88gt 5.0 Mustangs 7 July 25th, 2007 02:08 AM
Took my car to the track ColinGT Drag 8 April 23rd, 2007 10:15 AM
Can You Track Your Car Build Online? KIMMER 2005 - 2010 5 March 19th, 2007 01:08 AM
