Smog Pump
Old August 4th, 2008, 12:07 PM   #1
2002 V6/1967 Mustang
JasonMarshall is on a distinguished road
Smog Pump
Is there REALLY any reason I should leave my smog pump*on my 91? Besides emissions tests, since I do not have to worry about that .
2002 V6 Mustang/ 5 Spd, cold air, flowmaster exhaust, Hedman Headers
1991 LX 5.0 Convertible, Flowmaster 40's
1991 LX 5.0 Hatch, offroad h pipe, Flowmaster 40's 3.77's with a locker
Old August 4th, 2008, 12:57 PM   #2
1992 Lx
11.39@119.24
its bad to have cats and no smog pump pumping air into them, suposedly, so if you have no cats and no emissions ditch that pos
Old August 4th, 2008, 01:01 PM   #3
I suppose all I need to do is plug the holes in the head and new belt? Or do I have to do the Smog delete kit?
Old August 4th, 2008, 01:12 PM   #4
1992 Lx
11.39@119.24
smog pump deletes just so you dont have to run a shorter belt, kinda pointless when you can just run a shorter belt
Old August 4th, 2008, 05:27 PM   #5
sn94's Avatar
BLWN91GT
sn94 is on a distinguished road
iTrader: -1 reviews
Send a message via AIM to sn94
I just recently removed all the Smog/Emmissions crap. They sell plugs for the back of your heads. The only reason it has that metal pipe the connects to the back of your heads is for cold starting, So the H-Pipe would collect heat and heat up your heads. The other reason was to shoot out carbon build up. But I picked up the plugs and plugged them up. And save yourself $40-50bucks and just remove the pump and run a shorter belt. Did you remove your A/C? If so lemme know because I have the exact belt that fits perfect.
PaT #06
Old August 4th, 2008, 06:00 PM   #6
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
PaT #06
Sn94, I plan on doing this to mine. Whats the belt number or size? The setup I'll be running is A/C removed, Smog delete and Electric water pump....
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old August 4th, 2008, 09:17 PM   #7
Good lord no, I'm in Texas, I HAVE to have AC or I'll die a horrible stinky death
Threads Similar to: Smog Pump
smog pump imported_Gt_Jay 5.0 Mustangs 15 February 7th, 2008 02:09 PM
smog pump hopper 5.0 Mustangs 15 June 24th, 2007 12:21 AM
smog pump cali 5.0 Modular Mustangs 0 April 21st, 2007 12:08 AM
smog pump help stangzilla 331 5.0 Mustangs 2 March 11th, 2007 09:04 PM
smog pump cali 5.0 5.0 Mustangs 3 July 24th, 2006 01:03 PM
