What next?
LinkBack (1) Thread Tools
Old August 4th, 2008, 06:09 PM   1 links from elsewhere to this Post. Click to view. #1
ztweny8's Avatar
1991 Mustang Lx
N/A yet
ztweny8 is on a distinguished road
Send a message via MSN to ztweny8
What next?
You might have seen my other thread about deciding which Mustang to purchase. I ended up getting a 91 5.0 with the mods bellow. Just wondering what would be the best mod to do next? I'm looking for straight line performance just to clarify, and other than FI or Nitrous.
Motor:
-Rebuilt with 14,000 K
-Rods, crank, and bearings replaced (not sure on specs, I have to ask him)
-ARP Bolts
-Fel-Pro gaskets
-Stock heads Ported and Polished
-E 303 Cam
-Underdrive pulleys
-Edelbrock Performer upper and lower manifolds
-Calibrated mass air sensor
-BBK Cold air kit
-70mm Throttle Body
-Crane Fireball Ignition coil and controller
-255 LPH fuel pump and regulator
-Aluminum Rad
-Mac Shorties
-2.5 inch with H pipe
Trans:
-New clutch, pinion seal and fluid
-Hurst short throw
Drivetrain:
-Aluminum Driveshaft
-Ford Racing 3:73's
-New gear oil friction modifier
Brakes:
-New performance front rotors
-Hawk brake pads
-Upgraded large 73 mm front calipers
-Rear disc brake conversion, 93 cobra rotors
-93 Cobra Master Cylinder
-Adjustable proportioning valve
Suspension:
-Lakewood drag shocks and struts
-Steeda drag springs
-Right rear drag air bag
-Energy suspension polyurethane bushings
-Mac Caster Camber plates
-Adjustable upper and lower control arms
-Granatelli rear upper adjustable control arms
Chassis:
-Full length subframe connectors welded in
-Upper and lower Torque box reinforcements
-K member brace
-BBK Strut tower brace
-Car hand sanded underneath and covered with Tough truck undercoating
Accessories:
-Full gauge instrumentation
-Monster tach
-Autometer A/F, Boost, and Temp gauge
-Dry Cell battery
-Racing buckets
Tires:
-New set of Falken ZE512
-245/50R16 front and 255/60R15 rear
All parts taken off the car were sandblasted and powder coated, all rubber bushing and mounts have been changed to polyurethane.
Thats the mod list I got with the car. Only have had it for a few days. I e-mailed him and asked if it was ever dyno-tuned. I think that would be the next step if it wasnt. Cheap, gain a few HP, and get to find out what it puts down. And we have a really good Mustang tuner in our city.
I know some aluminum heads would probably help alot too. That would probably be something I would do next season. But could you recommend me a pair that would suit my engine?
Would 24lb Injectors help me?
Old August 4th, 2008, 06:46 PM   #2
ztweny8's Avatar
1991 Mustang Lx
N/A yet
And also, your best guess at HP/TQ and 1/4 mile
Old August 7th, 2008, 06:20 PM   #3
ztweny8's Avatar
1991 Mustang Lx
N/A yet
Anyone?
My goals are a evening/weekend street driver that runs low 12's on pump gas.
Old August 7th, 2008, 07:05 PM   #4
1990 Mustang GT
13.64 @ 101 MPH
GoodOleBoyzRacin is on a distinguished road
mid to low 13's depending on conditions, and most important.......traction and driver.
100-105 trap speed
no guesses on HP/TQ (im not good at that)
that a pretty clean car. a good set of heads and a better cam will get you into the 12's. no doubt.
90 Ford Mustang 5.0 T5- BROKE
1.9 60' on street tires13.64 @ 101 MPH
89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8
Old August 7th, 2008, 07:14 PM   #5
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
i recommend some sort of sticky tire
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old August 7th, 2008, 08:17 PM   #6
ztweny8's Avatar
1991 Mustang Lx
N/A yet
some MT street slicks are part of the plans.
What heads do you recomend for what I want to do? Dont want to have to change other parts to make them work either (intake etc.). Dont need to be the best of the best and cost a bunch, but some quality ones that give good gains.
Old August 7th, 2008, 08:31 PM   #7
Trans Am WS6
ThreeHonks302 is on a distinguished road
Send a message via AIM to ThreeHonks302
Thumper of Orange Park Sells awesome heads. Look at some of his reviews, im getting a set soon. Just search "Thumper of Orange Park" in google
Old August 7th, 2008, 08:38 PM   #8
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
I'd lose the stock heads and throw a set of Trick Flows on it.
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old August 7th, 2008, 09:26 PM   #9
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
Sleeper_Stang_89 will become famous soon enough
Thumper ported a guys e7's and he made it to the 12's... they guy actually won an episode of pinks... but I agree get some aftermarket heads... and a different cam...
331 ways to WASTE an LS1...
I love pink
Originally Posted by sgrcltpunk View Post
dont fuck with bad pussy
Old August 7th, 2008, 11:16 PM   #10
fordrarities's Avatar
1990 GT
fordrarities is on a distinguished road
Send a message via MSN to fordrarities
the cam you have will get the job done, theres plenty of good heads just depends on what you want to pay....
there is a guy on corral running GT40 irons w/GT40 explorer intake not ported or anything with stock cam runnin 11.9s. You can pick up a set of GT40 heads for cheap and just get them run through and ported if you want
1990 Mustang GT
Old August 8th, 2008, 02:56 AM   #11
1987 ford mustang gt
well see when shes done
i would look into trick flows if i were you and if you wanna do it n/a get a cgc.
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/83166-what-next.html
What next? This thread Refback August 10th, 2008 12:16 AM
