Discussing new heads for 86gt in the 5.0 Mustangs Forum. What do I need to do to put new heads on an 86gt? I've ...
Old August 4th, 2008, 09:33 PM   #1
AJSTANG's Avatar
1986 Mustang GT
new heads for 86gt
What do I need to do to put new heads on an 86gt? I've been reading that you can't just bolt them on because of the pistons. What needs to be done so that I can put them on? I'm looking at the trick flow kit, but I may just piece something together. I would like to get 350hp at the wheels. I plan doing suspension upgrades (springs, shocks, struts, cc plates, lower control arms, subframe connectors) and 3.73 gears this winter and next winter build the top end and finishing my exhaust sometime after that. So far I have a cat back flowmaster 2 chamber and k&n air filter. Is it worth building this engine or would it be cheaper to buy a crate engine? I wasn't planning on building up the bottem end, or even ripping it apart for that matter. Is there an easy way to solve this problem?
Old August 4th, 2008, 09:54 PM   #2
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
New pistons or a short block from an 87-95 Mustang.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old August 4th, 2008, 10:15 PM   #3
AJSTANG's Avatar
1986 Mustang GT
Thanks, thats what I was afraid of. I think I'll look into some crate engines before I drop a ton of money into this one.
Old August 4th, 2008, 10:30 PM   #4
1986 Mustang GT
nice to see a new fellow 4 eyer running around on the site.
MILITARY CREW
AT3
Old August 4th, 2008, 10:49 PM   #5
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
The Ford Racing 514 is nice.
Old August 4th, 2008, 11:05 PM   #6
AJSTANG's Avatar
1986 Mustang GT
A 514 would be nice But then I would have to change alot more things too. How hard is it to change to carburated? I see thats how most crate engines are.
Old August 4th, 2008, 11:09 PM   #7
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Its not hard but just because the crate engine has a carbureted intake doesn't mean you can't use EFI. You could buy a long block from Ford Strokers, DSS, Kuntz, CHP, etc. and put whatever intake on that you want.
Old August 4th, 2008, 11:18 PM   #8
AJSTANG's Avatar
1986 Mustang GT
Tell me if this sounds right.
MAF-$500
Top end kit-$2500
Pistons-$250
TB+EGR for trick flow kit-$250
Fuel Injectors-$300
Total of $3800 less tax for about 300hp.
I'm guessing to get 350 or greater I would have to build the bottem so I can get a whole rotating assembly for about a grand which would make it $4550, give or take. And if I stroke it I would have to pay for the machine work, and probably port and polish the heads since I'm having everything else done. That would probably put me in the 400's I'm guessing? But after all of that would it just be cheaper to buy a crate engine that still has room to build? I know I could turbo or spray now but I would rather have all motor.
Old August 4th, 2008, 11:19 PM   #9
AJSTANG's Avatar
1986 Mustang GT
That's the only difference? Damn, that sounds like the way to do it.
Old August 4th, 2008, 11:51 PM   #10
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Yep. All of the sensor and such can be swapped off of your current engine. You would need to upgrade to mass air though.
Old August 5th, 2008, 12:17 AM   #11
AJSTANG's Avatar
1986 Mustang GT
Well, I think what I will do is find a lx, do an engine swap and sell of everything I take out. My 86 is in almost perfect condition and I think it will be worth something down the road so I don't think I want to get rid of the original engine. What do you think would be a good engine? I found the 514 engine you said earlier. Would that be a good one to go with? If I go this route the more hp the better and I will probably go carburated. I want it for street/track. 625hp at the motor sounds good. Or would it be better to build one? Thanks for your help, I really appreciate it. You probably just saved me alot of wasted money. I think going this way will be more power for what I spend on it.
Old August 5th, 2008, 12:19 AM   #12
AJSTANG's Avatar
1986 Mustang GT
Here's a link to the one I found Ford Racing Performance Parts [M-6007-D514*]
Old August 5th, 2008, 12:20 AM   #13
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
I was actually joking about the 514. You could buy a 347 and make enough power to satisfy your need for speed. With a 514 you will have so much money tied up in the rest of the car to handle the torque and horsepower.
Old August 5th, 2008, 12:44 AM   #14
AJSTANG's Avatar
1986 Mustang GT
So something along the lines of this? Ford Racing 347 Sealed Race Engine - JEGS
I assume I will need a new tranny as well. Would that be an actual 347 or a stroked 302? I might end up building one though because why buy it complete just to change it later to get it the way I want it.
Old August 5th, 2008, 01:04 AM   #15
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
All 347s are stroked 302s. I'd call Ford Strokers for a quote before I'd buy a Ford Racing engine.
Old August 5th, 2008, 01:07 AM   #16
1987 ford mustang gt
well see when shes done
that would be a stroked 302. your best bet is to call fordstrokers, chp, kuntz, or dss like darrell said and put your topend of choice on it.
347 stroker little street car yea its slow!!
Old August 5th, 2008, 01:08 AM   #17
1993 5.ohhhh
14.47 at 96 mph
Ebay is your friend and forums to. I got 30 ib injectors for 80 bucks, a pmas 80mm maf calibrated for my injectors for 85 shipped to my door, and a v2strim complete kit for 1700. Just gotta keep your eyes out.
302 h/c/i
Old August 5th, 2008, 01:16 AM   #18
AJSTANG's Avatar
1986 Mustang GT
I'll have to check those out, but if its still a 302 wouldn't it still top out at 600hp? I know thats more than I want now but if I ever decide to go more I want to be able to. And I was reading on another thread on here that 347s aren't the most reliable either. I forget what it said exactly but it could of been someone not knowing what they were saying either.
Old August 5th, 2008, 08:59 AM   #19
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
I don't know what would make a 302 "top out" at 600 horsepower. Anyone that says a 347 is less reliable than a 302 should not open their mouth because they lack the intelligence to give any advice. A stock block can only handle so much horsepower and/or rpm but whether it is a 302 or 347 has no effect on reliability.
Threads Similar to: new heads for 86gt
86GT with 91front clip problems Yella01Stang 5.0 Mustangs 15 June 10th, 2008 10:50 PM
86GT pics and vid Squints The Clubhouse 9 March 14th, 2008 01:17 PM
86gt or 86svo nasty92LX 5.0 Mustangs 15 March 7th, 2008 08:38 PM
86gt 8.8 rear end mustang17 V6 Mustangs 8 December 11th, 2007 12:16 AM
Want to trade 86GT bigbadtalontsi Trade 4 April 12th, 2007 11:20 PM
