Discussing Rear Control Arms Install in the 5.0 Mustangs Forum. I just ordered a set of upper and lower control arms. Now im wondering about ...
Old August 6th, 2008, 07:44 PM   #1
1986 Mustang GT
I just ordered a set of upper and lower control arms. Now im wondering about install. How hard are they to install? Will I need any special tools? Can anyone who has done it before walk me through it? Thanks
Old August 6th, 2008, 08:41 PM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
Its pretty easy, keep a jacu under the rear end after you put the car on jack stands so that you can move the rear end around. Do one side at a time.
Old August 6th, 2008, 08:58 PM   #3
coreyflipp's Avatar
1990 Mustang gt
What brand did you get? I have my whole rear end out right now to install my 373's, al. driveshaft and I'm gonna paint it. You basically unbolt the old ones and then bolt the new ones in. I got the summitt rear control arms in today and will put them in when I put the rear end back in.
1990 gt 5-speed
Old August 6th, 2008, 09:36 PM   #4
1993 Mustang GT
The only thing I needed was an 18mm deep socket. I actually photographed and documented my install. If you're interested in seeing it PM me your email address...
Bart
93 Black on Black GT
Kenne Bell S/C
Old August 6th, 2008, 09:49 PM   #5
shadowgames81's Avatar
01 GT
Yeah its not hard at all bro had it done and back on the road in like 2-3 hours. Pretty straightforward install.
Eats rice daily
Old August 7th, 2008, 10:30 AM   #6
1986 Mustang GT
thats cool, it doesnt sound too bad, I was just wondering because my buddy did it to his 88 and he said it was a PITA. He said he had to use come-along to move the rear axle!!
Old August 7th, 2008, 10:30 AM   #7
1986 Mustang GT
So it is recommended to do one side at a time? both upper and lower?
Old August 7th, 2008, 11:17 AM   #8
MMs Official Playboy
1FastFox's Avatar
2006 Aston Martin DB9
Yeah, control arms are cake... Liek said, just do one side at a time. You will love the feel. WHat kind did you get?
D&D FTW...
Old August 7th, 2008, 12:26 PM   #9
1986 Mustang GT
I got the Mac Boxed Upper and Lowers from 50resto. They were cheap and looked pretty strong. I got them powdercoated black. They are non-adjustable. Is there really a whole lot of difference between aftermarket control arms?
Old August 7th, 2008, 03:09 PM   #10
dr.gonzo's Avatar
a breaker bar, 2 jacks, and 2 jackstands and a basic socket set. Put the jackstands high enough so that when you unbolt the bottom lower control arm bolt that you have room to get the spring out and your not hitting the ground.
oh and if your exhaust is welded you will need a sawzaw.
FREE LUNCH, FINAL
WISDOM, TOTAL COVERAGE... WHY NOT?
Old August 7th, 2008, 08:17 PM   #11
1990 Mustang GT
13.64 @ 101 MPH
id do both sides at the same time. just put a 2x4 under the diff and place the jack there. much quicker than doin one at a time and IMO its easier to line everything back up like that.
just jack it up, take off the back wheels, put the jack under the diff, take the shocks off the rearend, disconnect the upper c/a's, let the jack down slowly, remove springs, take the lowers off, and then go back in reverse with the new parts. if its quad shock throw the two runnin parrellel with the ground in the trash and while yer under there take that 10 lb weight off the bottom of the diff. not needed.
90 Ford Mustang 5.0 T5- BROKE
1.9 60' on street tires13.64 @ 101 MPH
89 Ford Mustang coupe- In Progress
5.0, TFS stage 1 cam, Edelbrock Perf, Holley 600 4bbl, Holley Blue FP & Reg, M/T Radials, Stock T5, MAJOR weight reduction ~ GOIN FOR 12.99
Old August 7th, 2008, 08:22 PM   #12
86_Notch's Avatar
1986 lx notch
10.78 @ 124.96
<-- summit ones here too, easy to install
vids of my car
the raggedy car you hear is the nova, he's running open headers and it's drowning out my car
http://www.youtube.com/v/P3-7Oobydyo&hl=en
http://www.youtube.com/v/rmPPnfHZ9WA&hl=en
http://www.youtube.com/v/HcD354133Ac&hl=en
Old August 7th, 2008, 08:26 PM   #13
86_Notch's Avatar
1986 lx notch
10.78 @ 124.96
hell yeah ! you're soooo right about what to do with the quad shocks and diff weight !!
vids of my car
Old August 7th, 2008, 09:29 PM   #14
1986 Mustang GT
thanks alot everyone. I cant wait to get them in, they're suppossed to be here Monday. Im thinkin after these get installed Im gonna order some 90/10 struts and some 50/50 shocks for a rear? Does this setup sound good? Will I notice any difference at all?
Old August 7th, 2008, 09:32 PM   #15
if you are planning on driving the car on the street much, you should go with a 70/30 in the front.. if its a track only deal, 90/10 will be fine
Old August 7th, 2008, 09:39 PM   #16
nolife's Avatar
I think the theory of doing one side at a time is to keep the rear end in the right place. With the whole rear end down, it will shift around and it can be a little tricky to get it lined back up in the right place again. Maybe on a lift and a jack holding up the rear that you can freely move around it would be easier. I just went through that with a lift kit I installed on my truck in my driveway. Its not that hard I guess but it takes a little moving around to get it right.
1991 GT - Original owner, all stock
1988 GT - The project car
Old August 7th, 2008, 09:56 PM   #17
1986 Mustang GT
What is really the diffeence between 90/10 and a 70/30. I have heard of both of them, but have never heard of anyone using a 70/30?
Old August 7th, 2008, 09:58 PM   #18
86_Notch's Avatar
1986 lx notch
10.78 @ 124.96
if you're gonna do drag struts you might as well go 90/10
btw i've got 90/10s and 50/50s and i love em toss the front sway bar while you're at it
vids of my car
Old August 7th, 2008, 10:31 PM   #19
TheBrat's Avatar
91 Mustang LX Fastback
1000.00
Notch, would you still recomnd pulling the front Sway Bar if you still wanna street drive it?
Also you used Summit Uppers? And what Lowers?
Thanks.
Brett!
91 Mustang 4cyl Project Car
5L (for now), AOD, Subframe Connectors, 10 Hole Rims, 8.8 Rear End.. MORE TO COME!
Yes my name is Brett, Yes im from Canada.. NO! My last name is NOT Hart!
Old August 7th, 2008, 10:32 PM   #20
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
I run 70/30's...
331 ways to WASTE an LS1...
Threads Similar to: Rear Control Arms Install
just installed rear control arms... :( MineralGreyGT Suspension 6 October 31st, 2008 02:59 AM
rear control arms jaxdawg 99-04 1 March 30th, 2008 06:39 PM
rear control arms on today marcd 99-04 35 January 12th, 2008 03:17 PM
Anyone use the BBK Gripp Rear Control Arms? Speedstang302 5.0 Mustangs 22 October 19th, 2007 10:28 AM
rear control arms bullitt1238 Suspension 11 October 18th, 2007 02:35 PM
