is there an easy way to take my fuel pump out? or no i dont wanna drop the tank...
it seems like to much of a hassle...
1990 Mustang GT
13.64 @ 101 MPH
gotta drop the tank. its only 2 bolts fer the 2 straps, i think 1 screw fer the filler neck, and it all falls out. dont break the fuel lines or bend/kink. its easy as shit depending on how much gas is in the tank.
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
#3 | |
1986 lx notch
9.98 @ 135
you could go ghetto and cut a hole in the trunk/hatch over where the pump goes in the tank but i sure as hell wouldn't do that
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
Rollin' 18/ pushin' 2
you can drain out the gas with a siphon, or make your own with a plastic bag and some tubing. it's not that hard to change, it's just dirty as hell. were some glasses or goggles because all kinds of dirt and shit is gonna fall on your face from around the tank and straps.
I just did mine - I had the tank down in 5 minutes and the pump swapped in 20. Took me about 15 to put the tank back on by myself. Do it it's easy.
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
87 Coupe
![]() iTrader: 3 reviews
I think there are 3 bolts for the filler neck and also when dropping the tank and pulling out the filler neck from the tank be careful not to tear the rubber gasket. Grease up the gasket before sliding the filler neck back in. It is a very simple job honestly bud. I just jack the tank down slowly after taking off the straps and lower it, pull the plugs and hoses. Might take you two hours man. Not hard to do at all.
Eats rice daily
1987 ford mustang gt
well see when shes done
Put one on a 92 z28 and then tell me how much of a hassle a mustang is.
Man its cake dont set around and whine about it or get scared your gonna screw something up b/c it goes in just like it came out.
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
oh that easy i thought it was hard... but i dont wanna go ghetto hahaha so yeah i can wait
1989 Mustang LX
10.98@126.7 NA
It's easy unless the car has been exposed to the crap they put on the midwest roads in the winter time, then it blows.
Never fast enough.
nope cali car...
1989 LX Vert - 1993 Notch
Fast
Filler neck sliding out of old rubber gasket is only pain.
Little WD-40 goes long way on the filler neck coming out easy. Just drive it around the neighborhood till gas gauge is on E That takes most of the gas out easy. 1-2gal left in there is no big deal. Good idea to go ahead and replace that filler neck seal while tank is down too. Cheap and they prone to leak when old.
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us |
ok thanks how much you think?
Fast
i love late model restoration....
Threads Similar to: is there an easy way to take my fuel pump out? or no i dont wanna drop the tank...
| Can 03-04 cobra fuel pump fit in a GT tank? | 03_StangGuy | 99-04 | 5 | June 4th, 2008 05:08 PM |
| In Tank Fuel Pump Upgrade | The Novice | 5.0 Mustangs | 7 | March 18th, 2008 04:48 PM |
| drop gas tank | Invictus | 99-04 | 9 | August 15th, 2007 12:09 PM |
| Quick Easy Questions .. Drop by | Youngin | V6 Mustangs | 38 | December 24th, 2006 12:31 AM |
