need tremec help!
Old August 7th, 2008, 10:37 PM   #1
built351w's Avatar
1979 mustang 5.0
hopefully 11's when complete
built351w is on a distinguished road
Exclamation
need tremec help!
Ok here's the deal:
I have a tremec TKO. I had it completely rebuilt because I got it from a junkyard. The input shaft had snapped clean off (yeah the driver died in the crash....) I had a transmission guy go all through it and he said it was fine, and he replaced the input shaft and seals ect...
I purchased a B&M short throw "ripper shifter" for a tremec part number 45054. This must be the right shifter because it bolts right up to the tranny.....
I recently got my clutch hooked up but even when I push the clutch all the way to the floor I still can't move the shifter!!! The shifter will move slightly to the right but thats it, harly any play at all. You cannot get into any gear, the tranny just stays in neutral! I tightened the adjustment screw on the clutch cable at the fork down so there's only about 1.5in more to screw, still no change at all.........
Any idea what's happening? Does it have to do with the throwout bearing or the shifter?
any help will be GREATLY appreciated!!! ask me if you guys need any more info!
-Devin
1979 hatchback:
-351w w/ 10.5:1
-Tremec TKO
Old August 7th, 2008, 10:42 PM   #2
built351w's Avatar
1979 mustang 5.0
here's a complete breakdown of a tremec tko if it helps:
http://hanlonmotorsports.com/3550-tko-lg.gif
1979 hatchback:
-351w w/ 10.5:1
-Tremec TKO
Old August 7th, 2008, 11:37 PM   #3
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
did you index the new bellhousing ???
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old August 7th, 2008, 11:46 PM   #4
built351w's Avatar
1979 mustang 5.0
alright I'm not sure what you mean by "index" but I have a lakewood scattershield specifically for a 79-93 mustang with a tremec transmission.....
1979 hatchback:
-351w w/ 10.5:1
-Tremec TKO
Old August 8th, 2008, 12:41 AM   #5
Fast
You need to index that bell housing.
The trans bolts to the bell housing and the bell housing bolts to the engine.
If the bell housing isn't perfectly centered and squared with the engine then
the transmission will be off also.
This should be done on any new bell housing install and is pretty
important to clutch engagement and throw out bearing life.
Lakewoods are also notorious for being pretty far off when bolted
on straight out of the box.
Your problem may be related to something else, but this is an important
first step to "properly" installing a new trans and bell house combo.
http://www.lakewoodindustries.com/pd..._procedure.pdf
Bellhousing Indexing Fixture
Bellhousing Indexing Fixture Instructions
God Help Us
Threads Similar to: need tremec help!
tremec 3650 or t-56?? 1fststang 99-04 12 July 3rd, 2008 04:41 PM
tremec tranny? built351w 5.0 Mustangs 8 November 1st, 2007 03:03 PM
T-45 Tremec Project_Stang 5.0 Mustangs 1 October 28th, 2007 08:06 AM
Tremec TKO??? 02StangGToWNEr 99-04 0 October 11th, 2007 06:09 PM
tremec t-5 doorvip 5.0 Mustangs 0 December 11th, 2006 09:20 PM
