1992 Mustang GT
Coming soon...
What size MAF
Getting ready to install my 'p heads and comp xe270 camshaft, and looking to get a new MAF. I have heard that you want to go a little larger on the MAF than the T/B? Is that true? My car currently has a 75mm t/b on it, which is a little big since the Performer intake only has a 70mm opening but the car seems to perform just fine. That isnt hurting anything is it?
So should I get rid of the 75mm t/b and pick up a 70mm t/b and 75mm MAF, or should I keep the 75mm t/b and pick up a 80mm MAF? Also, I plan on spraying a dry 125 shot on top of this combo, so what size injectors should I go with? thanks
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work |
The biggest MAF you can find. I'd put the stock throttle body back on or an Explorer 65mm throttle body. That 75mm is too big. Stock injectors will be fine but 24lb injectors will give you room to grow in the future.
1992 Mustang GT
Coming soon...
So 24lb injectors are enough for h/c/i and a 125 dry shot? I figured I would need a little bigger.
Also on the explorer 65mm t/b is there anything I have to modify on it or will it bolt right up? thanks
1992 Mustang GT
Coming soon...
it isnt letting me edit, but I found info on converting the t/b!
Threads Similar to: What size MAF
| maf size | marcd | 99-04 | 18 | May 27th, 2008 04:28 PM |
| MAF Size | imported_Gt_Jay | 5.0 Mustangs | 9 | December 14th, 2007 09:00 AM |
| maf size? | superman5.0 | 5.0 Mustangs | 5 | July 28th, 2007 08:06 PM |
| Injectors and MAF size. And other questions.. | One Bad Sixxx | V6 Mustangs | 16 | June 4th, 2007 08:14 PM |
| what size injectors and maf should I use? | fogged306 | 5.0 Mustangs | 27 | April 22nd, 2007 10:48 AM |
