1988 Mustang
fuel pump
BBK fuel pumps, good or bad?
there good.... but if your stock prob shouldnt get one..
1989 GT
KB 2.1L Flowzilla
Its a Walbro pump, if you look around you could save few bucks. I went with BBK, im happy with it. Its a nice kit, comes with everything needed. Change the fuel filter also while your at it.
Good pumps.
1995 Mustang GT
Just about every fuel pump out there is a Walbro pump. Doesn't matter if it comes from BBK, Trick flow, etc. BBK's are kind of expensive. What size pump are you looking to put in?
See garage for mods |
#6 | |
1988 Mustang
fuel pumpCome to find out when I pulled the pump that was in the tank someone who had the car before me had already changed the pump looked like the same kit that I baught just not sure what size it was the first set of numbers on the pump were different than the new pump. |
thats funny it went bad fast then....
1988 Mustang
fuel pump |
1989 Mustang GT
Even if ur stock just get a pump and adj fuel reg and adjust to desired needs. Once you upgrade anyway you'll need one sooner or later might as well get it outta the way now since ur already thinking about it.
![]() Ported Saleen Vortech Intake BBK 70mm t/b,BBK CAI,BBK Reg,BBK 255 Fuel Pump Hooker Super Comp Long-tube Headers Fcam Ported Motorsport J302 Heads 30# Injectors 1.6rr 80mm Mass Air 4:11 gears |
thats whayt i said if your stock your going to be eating gas.... 255 is way to much thats for performance you would be fine with 190
How will you use more gas with a bigger fuel pump?
no im saying there is no reason to have it if hes stock.....
95 Mustang GT
sure there is a reason its called getting your supporting mods taken care of....so many newbies jump in here and want to put in bigger maf or bigger TB or this or that and want to know how much its going to add....they are supporting mods that are needed to go with other things bro....and I would no go smaller than a 255 if you are going to the trouble to change it do it once and be done the price difference is minimal if any....
1988 Mustang
fuel pump |
You clearly said " if your stock your going to be eating gas.... 255 is way to much thats for performance you would be fine with 190". A bigger fuel pump won't make the engine consume more fuel. If you are going to go thru the hassle of putting a bigger pump in you might as well get the 255lph right away so you have room to grow. The pumps have about a $7 difference in price so why not get the big one. That is what everyone is saying.
1987 ford mustang gt
well see when shes done
What does your combo consist of?
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
1988 Mustang
motor |
its like twenty... i jut got the 190 lph idk everyone told me not to go with something so big but if he has 400hp thats prob perfect dont know why i said the gas thing...sorry
Threads Similar to: fuel pump
| Fuel pump question. Stock GT pump to GT (supercar) pump. | Nate's4.6 | 99-04 | 15 | May 14th, 2008 02:25 PM |
| Suggestions on Fuel Cell's & Fuel Pump | bstang | 2.3 Mustangs | 5 | January 21st, 2008 09:04 AM |
| fuel pump fuel pressure stuff | JBIGBOOTSY | 5.0 Mustangs | 2 | April 26th, 2007 03:31 PM |
| Fuel pump | Mustang Mike | 99-04 | 1 | February 24th, 2007 03:26 AM |
| Fuel Pump | Tony_90fox | 5.0 Mustangs | 6 | November 3rd, 2006 01:46 PM |
