pcv valve replacement
Old August 10th, 2008, 07:09 PM   #1
white nite's Avatar
1987 mustang lx 5.0
white nite is on a distinguished road
how hard would it be to replace my pcv valve with the upper intake manifold still bolted to the motor
Old August 11th, 2008, 12:38 PM   #2
teal89's Avatar
89 Mustang Lx
teal89 is on a distinguished road
Not hard at all, reach back there and pull out the PCV valve, replace it with the new one, put it back in. You should be able to do that without even looking. While you're at it, take out the pcv filter in there located below the pcv valve and spray it down with some carb cleaner to clean the gunk out of the filter and replace it back, or buy a new one.
94-95 306, B-Cam, Off-brand BBK Like Headers, H-Pipe, 3.73's, Nitrous Wet Shot 175 Shot
Old August 11th, 2008, 02:12 PM   #3
white nite's Avatar
1987 mustang lx 5.0
thanks for the info. i'll do it sometime this week and i'll see if it fixes the problem of the oil pan bolts coming loose
Old August 13th, 2008, 03:10 PM   #4
teal89's Avatar
89 Mustang Lx
Uh dude, replacing a PCV valve will not help your oil pan bolts from coming loose. You need to make sure you torque correctly and not using Home depot bolts. If you have crankcase pressure problems be ready for a rebuild. If your bolts are coming loose, you have a whole new problem so never heard of that.
Old August 13th, 2008, 03:45 PM   #5
ryans88gt's Avatar
PCV valve, use only the motorcraft ones, the autozone and parts store ones are junk.
Bolts coming loose? Never heard of that, I always use silicone on the oil pan and that tends to keep the bolts from turning. You can always use thread locker, just use the weakest strength.
Old August 14th, 2008, 12:34 AM   #6
white nite's Avatar
1987 mustang lx 5.0
that is going to suck if i have to rebuild the motor cuz i don't make enough money to do that. i am using actual oil pan bolts. i tried torquing down the oil pan bolts but i ended up snapping one. the only bolts that keep coming loose are 3 one the passenger side of the engine right over the crossmember, since i have a stock k-member i have to use one of those u-joint extensions so i don't know if i am tightening them up enough
Old August 14th, 2008, 12:39 AM   #7
white nite's Avatar
1987 mustang lx 5.0
i took the pcv valve out and shook it and it still rattled, i took the pcv filter out and sprayed it down with carb cleaner. the filter wasn't that dirty suprisingly.
Threads Similar to: pcv valve replacement
PCV valve I_eat_rice 99-04 2 April 9th, 2008 04:42 PM
Egr Valve And Pcv Valve Delete? Jeffery9508 V6 Mustangs 16 January 28th, 2008 09:45 PM
pcv valve? El_Cangri V6 Mustangs 12 June 1st, 2007 10:07 PM
Where Is It? (PCV Valve) cobraetti General Tech 3 August 6th, 2006 09:16 PM
PCV Valve Replacement on 87 GT cobralini 5.0 Mustangs 9 May 18th, 2006 06:59 PM
