Still more problems
Old November 23rd, 2006, 10:44 PM   #1
Lax89 is on a distinguished road
Still more problems
In my first post i mentioned that my 88 had a nasty squeak, its auto but it seems to be coming from the tranny, the car shifts fine and everything but it happens only when the car is moving, so i cant exactly get down there and look. Any ideas? and...i cant get the heat to work, the vents dont turn on and theres no signs of a messed up heater core. Any ideas here?
Old November 23rd, 2006, 10:53 PM   #2
Mustang8719 is on a distinguished road
Does it only happen when you are on the gas?
If si then check the Driveshaft u-joints.
For the Heat check under the hood and make sure all the vaccum lines by the firewall going inside are good.
Eibach lowering springs,Intake ported to Max,Electric cooling fan,120Amp Alt.,FlowMasters,Jacobs FC1000 Ignition system with coil,King Cobra Clutch,APC Racing Seats
Old November 24th, 2006, 12:09 AM   #3
Its not only when i step on the gas, its all the time, even slowing down, could something just need to be lubed?
Old November 24th, 2006, 12:12 AM   #4
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
im in the same boat but i have a t5
85 svo. work in progress
Old November 24th, 2006, 12:24 AM   #5
so any input? or are we both just saying...WTF IS THIS!?! lol
Old November 24th, 2006, 12:29 AM   #6
the condition my car is it could be anything theres deff noise coming from my tranny that i dont like lol
Old November 24th, 2006, 04:25 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The squeak is very possibly a u-joint. Pull the driveshaft out and check the u-joints. It should be really obvious if one is bad enough to squeak. It will be really tight. As for the heat, check all of your vacuum lines. The switch is vacuum operated, that is how it switches from defrost to vent and so on.
Threads Similar to: Still more problems
2.3L Problems. akatagyourit 2.3 Mustangs 51 June 25th, 2007 03:39 PM
more problems ks_emt 2.3 Mustangs 7 June 7th, 2007 03:16 PM
EEC IV problems tekt 5.0 Mustangs 3 February 19th, 2007 01:00 AM
88 GT With A Few Problems Iceman1989 General Tech 3 November 14th, 2006 12:58 AM
Help Please (Car Problems) 98mustang98 V6 Mustangs 1 October 25th, 2006 10:49 PM
