Water temperature
Old August 11th, 2008, 05:00 PM   #1
shurb125's Avatar
1993 Mustang LX Vert
shurb125 is on a distinguished road
Water temperature
I just installed some new Autometer gauges one being the water temp. I know the original car gauge ran to 270 but the new one only runs to 250. After a while of driving hard and not so hard the temp seems to stay around 230, is that running to hot or is that normal? I'm running an Taurus elec fan on high speed wire with a Delta Current Control unit with underdrive pullies. Thanks for all your help in advance.
306 TFS heads stage 3 port & polished, TFS stage 2 cam, TFS Track heat intake, DSS pistons, 24# injectors, 76mm MAF, 70mm BBK/Edelbrock TB and spacer
Old August 11th, 2008, 05:15 PM   #2
1983 mustang lx
83fox is on a distinguished road
thats a little too hot for my comfort. id say 195-210 would be about perfect
Old August 11th, 2008, 05:18 PM   #3
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
+1 You're in the upper zone of discomfort for my liking.
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old August 11th, 2008, 06:06 PM   #4
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
That's the max I would ever want to see. 200 range would be alot safer with a small cushion for safety.
Never fast enough.
Old August 11th, 2008, 06:42 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That is a bit warm.
Old August 12th, 2008, 03:05 AM   #6
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
Originally Posted by Darrell View Post
That is a bit warm.
Just a tad. Could be worse.
Old August 12th, 2008, 10:11 AM   #7
shurb125's Avatar
What do you guys reccomend I do to get it to cool better?
Old August 12th, 2008, 10:45 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I have no idea what a Delta Current Control is but that Taurus fan should be keeping it cool. What thermostat is in it? How hot is it outside when it is running 230 degrees? I know in extremely hot temperatures there isn't much you can do. My Suburban ran pretty hot in Las Vegas when the temp got over 100 degrees.
Old August 12th, 2008, 10:52 AM   #9
jrh_1980's Avatar
89 Mustang LX
7.90@90mph 8th
jrh_1980 is on a distinguished road
pull the thermostat and see if that helps. if the temp stays low then try putting a cooler thermostat in. your cooling fan control may need to be adjusted. I would let the car cool off then start it and let it run until the upper hose starts to get warm. this indicates the thermostat has opened at that point i would adjust the temp control for the fan until the fan kicks on. give her a try and let us know how it goes.
Old August 12th, 2008, 11:04 AM   #10
Quetzali1 is on a distinguished road
Did you replace the tempature sender? Also make sure that the fan actually works when hot. My dad's car had the electrical go out on him. So we jerry rigged the fan to always be on. Needless to say it didnt overheat anymore. Also, make sure that any gaps are closed off around the radiator. It tends to reduce the cooling power of the fan.
Old August 12th, 2008, 04:04 PM   #11
shurb125's Avatar
It has a 180 or 185 degree thermostat, the outdoor temp is anywhere from 95 to 100 last week.
Old August 12th, 2008, 04:07 PM   #12
shurb125's Avatar
Yes I did replace the sender with the new one that came with the Autometer gauge. The fan works but it seems to hit the high speeds too late.
Old August 12th, 2008, 04:13 PM   #13
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
Pulling the termostat can make the problem worse. I run a restrictor with a 3/4" hole in it and no stat. The highest temp I've seen on a 100 degree day at the track after a run is 210. Normal street use around town on 90+ days is 195. I use a Moroso electric pump, 14" Be-Kool pusher fan and a Summit aluminum (universal) radiator.
Never fast enough.
Old August 12th, 2008, 05:22 PM   #14
1988 mustang gt
rjay is on a distinguished road
did you change the clutch fan?
Old August 12th, 2008, 06:20 PM   #15
shurb125's Avatar
I cranked the car after sitting from 9 PM till 4 PM the next day and did what you advised, the top hose started to get warm at about 160 - 170 as far as the new gauge shows. What would be your advice? Thanks for all your help guys!
Old August 12th, 2008, 06:21 PM   #16
shurb125's Avatar
I'm running an elec fan, the clutch fan assembly is gone.
Old August 13th, 2008, 10:38 AM   #17
jrh_1980's Avatar
89 Mustang LX
7.90@90mph 8th
as soon as the stat opens and the upper hose gets hot that is when you should start backing down the adjustment on the temp control unit. you want the fan to kick on shortly after the stat opens.
Threads Similar to: Water temperature
Temperature Reading High Fastback91 96-98 40 November 22nd, 2007 02:24 PM
Water Temperature burnout5.0 94-95 5 July 9th, 2007 05:07 PM
temperature gauge issue 2004GT Audio/Video 2 May 13th, 2007 08:54 PM
Temperature Gauge lwhitetrash88l V6 Mustangs 4 April 14th, 2007 10:06 PM
1995 Mustang V6 temperature issues I_CTCHR95 V6 Mustangs 1 November 5th, 2006 09:43 AM
