Need help, I'm stumped!!!
The car idles fine after the top-end rebuild, but when it's given gas it just wants to die. Fuel pressure gauge is sitting around 34lbs when the car is running, vacuum line off 39.5-40lbs, but the needle is all over the place when you give it a shot of gas. The fuel pressure spikes when you open the throttle, and then drops off into the 20lb range. Is it supposed to be this way? WTF?
I originally thought the new MAF and injectors were dumping too much gas into the motor, so Steeda burned me some tunes which lowered the fuel delivery rate by 10% and another for 20%. It definitely idles better, and isn't running as rich but I still can't drive it, and I need to drive it 400 km next Monday for it's dyno tune! ANY pointers or suggestions please! FYI - new plugs, new cap and rotor, new fuel pump and filter, boost gauge shows the car pulling about 10 in of vacuum at idle. The tune Steeda gave me takes the O2 sensors right out of the equation as well... Check out the attached video for the exact symptoms:
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
supercharger sounds awesome-i need one of those
back on topic, its definetly a fuel issue, on my dads turbo car it did a similar thing every time we gave it gas. it turned out that we needed to just adjust the FPR, but it seems as if you messed with all this already, so i dunno
![]() 1990 Mustang GT |
What's really messing me up is the way the gauge jumps around - shouldn't it be more constant instead of fluctuating up and down when I give it gas?
This is the last thing I need to work out and it's driving me nuts. Anybody else had this issue and been able to fix it?
#4 | |
How does it run with the supercharger belt off?
My old man came over and yanked the connector off the MAF, and the car ran perfect. It revved right up to redline with no sputtering or stalling. Plugged it back in - problem returned. We checked all the wiring, and it tested fine, so it must be the sensor. Piece of crap thing has probably been my issue all along.
Ordered a new SCT BA-2600. At least I've learned about fuel pressure and how it's supposed to flow. Thanks for the help everybody.
#6 | |
#7 | |
#8 | |
Yeah - it's one of the few used parts I bought off another Mustang guy. I'll pop the new one in Wednesday when it gets here and if that solves it, I'll tell him he sold me a POS, and that I'd like my money back.
idk... maybe im just not seeing this correctly... but the MAF looks to be backwards...
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
You might be right.....I think the side with the flange is the air filter side. At least on the two that I have the flange is the air cleaner side.
the flange IS supposed to face the air filter... I bet thats the ENTIRE problem
#13 | |
If you guys are ever in Ottawa, let me know - I'm buying the beers.
I'm on my way right now!!!!!!!
Glad you got it fixed.
Good catch AdderMk2. The rest of us scanned right over that in the pictures and missed it.
Me too - 1000% difference! Now the metered air is actually going into the motor. Ha ha! This'll go down as one of the stupidest things I've ever done.
You guys have no idea how happy I am. I would have spent another $300 for nothing. I've ordered the keg - let's rock!
#17 | |
That shit happens dude, don't sweat it.
#18 | |
Threads Similar to: Need help, I'm stumped!!!
| I got stumped | Regency 2007 | The Clubhouse | 19 | June 20th, 2008 01:45 PM |
| FI. I've asked this before but I'm stumped | energiesource | 99-04 | 14 | October 29th, 2007 07:07 PM |
| stumped... | jessy_is_rad | Classic Mustangs | 19 | April 30th, 2007 01:13 PM |
| Okay, I'm stumped | SoonerBorn | V6 Mustangs | 18 | March 10th, 2007 02:20 AM |
| I need help im stumped | PonyRunner | Classic Mustangs | 1 | February 19th, 2007 01:59 PM |
