Upper Control Arm Install
I just put my new lower control arms in today. I still have to do the uppers and it looks like they are not gonna line up very easily to the bracket on the rear axle. It looks like the rear axle shifted to the right. Has anyone had this problem? Any advice for moving the rear axle around?!?
#2 | |
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
It just seems so difficult to move the damn axle... its so heavy. Im glad that I at least got the lowers in
1986 lx notch
9.98 @ 135
don't tighten the lowers till you get the uppers on , leave everything loose till you get both uppers and lowers and shocks all bolted up, then go ahead and tighten everything up. nothing lines up exactly perfect but with a little persuasion you'll get it, i did mine myself also
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
ok thanks hopefullt I can knock it out tomorrow morning and start putting in the springs/shocks/struts... So much to do still!! lol
1986 lx notch
9.98 @ 135
you put the lowers in without putting the springs on first ?
I don't know if this is a good way or not but I've moved my rear end around with an extremely large bar (like a 6ft gorilla bar or 2x4) against the ground under the axle and wedged up against the rear drum. You lift up on the bar and leverage does the work. Make sure you don't tip the car off the jack stands.
1986 lx notch
9.98 @ 135
oh ok, i was a little baffled but now i got it > : 0 )
it looks like im just gonna have to find a way to muscle them in... How hard is it going to be to change out the front springs?
1986 lx notch
9.98 @ 135
want to know how ghetto i was when i did the front springs on a couple of my previous cars ? i rented a spring compressor to compress the springs but the springs wouldn't fit with the compressor compressing the springs so i compressed the springs, put 3 large hose clamps on the springs and tightened em down really tight, put the spring in and cut the clamps off with some cutters. you can do this without a compressor by just alternately tightening down the clamps but this is VERY DANGEROUS and ghetto but sometimes you have to do what ya gotta do to git er done
Threads Similar to: Upper Control Arm Install
| Install Upper control arm.. | 2006greyGT | 2005 - 2010 | 7 | March 23rd, 2008 09:28 PM |
| Should I Replace My Upper Control Arm | Faulconer | 2005 - 2010 | 6 | June 14th, 2007 12:59 AM |
| Upper & Lower Control Arm | stang94 | 5.0 Mustangs | 5 | March 14th, 2007 07:21 PM |
| Upper & Lower control Arm install | stang94 | 5.0 Mustangs | 3 | January 11th, 2007 09:53 PM |
| Upper and Lower control ARM? | stang94 | 5.0 Mustangs | 9 | December 6th, 2006 11:39 AM |
