thermostat
Old August 12th, 2008, 05:22 PM   #1
88stang's Avatar
1988 Mustang
88stang is on a distinguished road
thermostat
I have heard two different things. Stick with a stock thermostat which I beleive is a 195* but some people have told me, considering what has been done to my motor, to run a 165*. Does it really matter?
Old August 12th, 2008, 06:30 PM   #2
1983 mustang lx
83fox is on a distinguished road
i think with the efi motors 165* would be too cold, causing the motor to run a little richer but i could be wrong.
180* is a pretty common choice for mustangs
Old August 12th, 2008, 06:33 PM   #3
93lx306dev's Avatar
1993 ford mustang lx 302
13.2 @ 104mph
93lx306dev is on a distinguished road
Send a message via Yahoo to 93lx306dev
i just put a 160* in my car.. my car has never ran so good.. my car runs at about 172* all the time..
FORD = FOUND ON ROAD DOMINATING
www.myspace.com/stangdevin
Old August 12th, 2008, 06:41 PM   #4
1983 mustang lx
ah, i missed the part where you said 'considering whats been done to my motor'
you might want to run a 160 then
Old August 12th, 2008, 06:49 PM   #5
shurb125's Avatar
1993 Mustang LX Vert
shurb125 is on a distinguished road
What has been done to your motor? The reason I ask is because I'm having cooling problems and just curious as to what works out for you.
306 TFS heads stage 3 port & polished, TFS stage 2 cam, TFS Track heat intake, DSS pistons, 24# injectors, 76mm MAF, 70mm BBK/Edelbrock TB and spacer
Old August 12th, 2008, 07:56 PM   #6
88stang's Avatar
1988 Mustang
motor
Motor: 347, gt40 upper and lower, Msd probillet distributor, msd 6a, msd tfi coil, 70mm eldebrock bbk throttle body, 76mm C & L maf calibrated for 30lb injectors and all the other quick mods such as under drive pulleys, gears, cold air and headers.
Threads Similar to: thermostat
Thermostat? burnout5.0 94-95 7 November 9th, 2007 05:57 PM
Thermostat.... lwhitetrash88l V6 Mustangs 3 June 19th, 2007 03:36 PM
thermostat JBIGBOOTSY 5.0 Mustangs 2 May 24th, 2007 08:35 PM
Thermostat Onemanzu V6 Mustangs 2 April 20th, 2007 07:00 PM
Thermostat Pony_with_an_attitude 5.0 Mustangs 7 March 28th, 2007 10:26 PM
