starting problem
Old August 12th, 2008, 05:41 PM   #1
88stang's Avatar
1988 Mustang
88stang is on a distinguished road
starting problem
Has anybody had any issues with their car not wanting to restart after it has been driven a while or after it has been running and reached a normal operating tempature? I know this is not a timing issue the car turns over fine. It may have something to do with to much fuel but I have installed brand new 30lb injectors. And before I ever rebuilt my motor it had the same problem with 19lb injectors. Pretty much everything under the hood is brand new.
Darrell has been trying to help me with this and I really appreciate it, but I thaught I would ask everyone who surfs this forum just in case they have ever experienced the same problem.
Motor: 347, gt40 upper and lower, Msd probillet distributor, msd 6a, msd tfi coil, 70mm eldebrock bbk throttle body, 76mm C & L maf calibrated for 30lb injectors and all the other quick mods such as under drive pulleys, gears, cold air and headers.
Old August 12th, 2008, 06:10 PM   #2
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
did you check the coil ? or that thing on the side of the dist ? i know i must sound dumb but i've never had a problem with it but more then 1 of my buddies did, it seemed to happen after the motor warmed up not when it was cold. sorry i can't be more specific but again i'm not much on efi
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old August 12th, 2008, 07:55 PM   #3
88stang's Avatar
1988 Mustang
Yes. Even before I rebuilt the motor I had changed that and know I have a MSD distributor and it came with one so it is new.
Old August 12th, 2008, 08:02 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I've seen alot of MSD ignition modules go bad. If you have a stock module it wouldn't hurt to try it.
Threads Similar to: starting problem
Starting Problem Reset 99-04 2 November 11th, 2007 03:44 PM
problem starting Fastpitchdad General Tech 12 May 23rd, 2007 08:00 AM
Starting Problem Snipe061 V6 Mustangs 9 March 22nd, 2007 05:52 PM
Problem starting up sbx213 5.0 Mustangs 5 March 11th, 2007 11:46 PM
Starting Problem? cobraetti General Tech 1 September 10th, 2006 11:21 AM
