Door lock problems
LinkBack (1) Thread Tools
Old August 13th, 2008, 09:36 PM   1 links from elsewhere to this Post. Click to view. #1
rusty2407's Avatar
1991 Ford Mustang LX
rusty2407 is on a distinguished road
Door lock problems
My driver side door lock is all messed up, the power switch wont lock the door and neither will the key, i cant even push the pin down manually. i dont think my lock cylinder is messed so im thinking it can only be the actuator right? but why would that keep me from locking it with the key?
BBK CAI and Shorty Headers, Cobra Upper/Lower Intake, Walbro 110, 24# Injectors, larger throttle body, maf, Drilled and slotted front rotors, King Cobra clutch, Cobra wheels w/ sumitomo tires, flowmasters
Old August 13th, 2008, 09:38 PM   #2
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Cause when you lock it with the key it moves your actuator too
Your actuator is junk its stuck. Got to the junkyard and pull one from a junker or buy one from Latemodel Restoration Supply - Mustang Parts, Chevy Truck Parts & Dodge Challenger Parts
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old August 13th, 2008, 09:41 PM   #3
rusty2407's Avatar
thanks, i ordered one at advance today, should be in tm, any idea on how to install one? no instructions in the haynes manual and ive never messed with them before. its held on by a rivet but would it be possible to use a short bolt? i dont have a rivet gun
Old August 13th, 2008, 09:51 PM   #4
Drick's Avatar
I never used a bolt before I dont know if you'll be able to get the nut on the other side
You just need to take off your door panel then drill out the rivit un hook the wire running to it. Then there should be a rod that hooks to the lock cylinder by a little hook on the end of the rod. Make sure the new one goes in the way you took it out the rod in the raised or lowerd position. Then hook the loop of the rod around the lock cylinder where it goes then put a rivit in the one side and pop it shut. You might be able to use a bolt but I dont know you'll have to look at that. Then instal the door panel and your done. Its pretty simple once you see it you'll see how it goes
Let me know how it works for ya
FX4 Crew
Crew member #1
Old August 16th, 2008, 01:48 PM   #5
rusty2407's Avatar
im thinking about just trying to unclip it from the plastic bracket, ive heard some ppl have had luck with that but for some it breaks, so idk. ill let you know tho
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/84450-door-lock-problems.html
Door lock problems This thread Refback August 13th, 2008 10:02 PM
Threads Similar to: Door lock problems
Driver door lock is stuck. Can't open door Help!!!! White 89 5.0 Mustangs 25 April 26th, 2011 12:49 PM
Door Lock Actuators Z28Eater 2.3 Mustangs 4 January 2nd, 2008 02:16 PM
my door lock, grrrrrrrr...... 93fourbangerstanger 2.3 Mustangs 90 November 13th, 2007 03:59 PM
Door lock motors jblood37 99-04 10 April 21st, 2007 09:41 PM
