new guy tryin to figure out a set up
Ive got a 351 im building for my 86, what cr would one suggest to run for the jug.
I plan on runnin a 150 shot on the motor. I know nitrous likes compression, but too much is also one thing. Friend and I are leanin towards 9-9.5:1 or so would appreciate any input
Just a truck 5.4 3v: 264hp 317ft lbs rock stock piecing together the next project faster than your first sexual experience |
Well i guess the 9 or 9.5 wins since we all seem speechless =)
I am not a expert on nitrous at all but I know that the F-body camaro's can run 100-150 shot on stock internals well the LT1 can that's what my buddy has and does you could go higher in compression is what I am getting at I mean if you have the time to build and put in the right internals you could go a little higher I mean the LT1 runs somewhere in the high 10 to 11:1 area I am pretty sure I mean like I said I am not a expert but I would run a higher compression then 9 for sure that is what I am running for my turbo setup engine I hope this helps man have agood one.
94 Mustang Gt Cold Air Intake Header back exhaust H-Pipe Flowmaster Mufflers MSD Dist UPR upper and lower control arms UPR sway bar all spherical bushing in rear on the way HP Turbo Stage II Kit 331 Long Block |
Do you want to run on pump gas? Is that the question? If running race gas isn't an issue, run the compression as high as you can get it.
#5 | |
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
id like to keep it on pump gas, if race gas is needed i dont wanna be dumpin c16 in it
If you want to run on pump gas while spraying keep the compression at a maximum of 9.5:1. Run at least 92 octane when spraying.
1988 Mustang GT
N/A
I agree, nothing higher than 9.5:1 on pump gas.
Threads Similar to: new guy tryin to figure out a set up
| cant figure it out | notsoslow50 | 5.0 Mustangs | 7 | July 12th, 2007 10:25 PM |
| Tryin for 300hp | unhungzero | V6 Mustangs | 26 | June 24th, 2007 01:42 AM |
| Figure this out... | Foxstang90 | 5.0 Mustangs | 3 | February 18th, 2007 01:15 AM |
| Need Help... Cant Figure Out | mustangrebuilder | Classic Mustangs | 5 | September 7th, 2006 12:48 AM |
| cant figure it out | ttop5.0 | 5.0 Mustangs | 2 | August 26th, 2006 07:54 PM |
