What size injectors?? 24lb 30lbI
I have a 94 Cobra I have just installed Pro ported GT40s, Tmoss ported Cobra intake. Crane .529 .544 lift 220 226 duration, headers etc. I have a 77mm Pro-M calibrated for 30 lb injectors. Anybody think 30lbs are too big or should I use 24lb and have the meter re-calibrated?? Thanks
1994 MUSTANG GT
in my eyes bigger is always better
2002 Gt
Not Slow
![]() iTrader: 1 reviews
go with 24's, you'll be spitting gas out the pipes with 30's
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
1993 5.ohhhh
12.97 @140mph
30lbers should be fine, and give you room to expand if you ever want to.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
Cobra came stock with 24# injectors you should be fine up to about 400 n/a if you go forced induction then step up
#6 | |
Wow horrible statement .....lol.....might as well put a victor junior intake with a big .600 lift cam......
.........30 lbers are to big IMO........... I have 19's with a 75mm pro flow and they work just fine.... No need for a bigger injector on that combo.... But like HELLRAZR94 says"bigger is better" So go with some 42 lbers
PeteAndersonRacing.com |
#8 | |
but i wld do 24s
![]() 1990 Mustang GT |
#9 | |
Big timin' in a small town
Thanks, it sounds like a split decision. Since I have a set of 24 and 30's and my mass air is calibrated for 30's, I may try them. It is not that hard to switch to 24's if 30's are too big. Thanks Dave
Are you referring to me?
Thats a big 10-4
go with the 30`s then you can use your pro-m
plus you will have room to grow and not have to worry about jumping up high after you start making big numbers |
Threads Similar to: What size injectors?? 24lb 30lbI
| 24lb injectors | worlz08 | 5.0 Mustangs | 4 | June 13th, 2008 05:27 PM |
| 24lb injectors? | shaunnj007 | 99-04 | 10 | February 12th, 2008 06:21 PM |
| Do I Need 24lb Injectors? | 88dragstang | 5.0 Mustangs | 10 | November 23rd, 2007 01:43 PM |
