#21 |
You have to have a fuel disconnect tool the fuel lines coming from the tank and a SS line wrapped in what appeared to be a sheathing
#22 |
You dont need fuel line tools....just a flat blade to pry the plastic clips out....dont know what everyone is talking about....
PeteAndersonRacing.com |
#23 |
There not plastic clips there metal. There are four of them. They all click into position around the fuel sending neck. The line has the metal clips in it that surrounds the neckand clips on . Plastic clips is for the fuel filter.
#24 |
All of my cars have had plastic clips.....
#25 |
That's odd cause fuel eats plastic away. Maybe in 94 when then went to the sn95 body they used metal instead of plastic but every car i have worked on has always had Metal clips inside the fuel line that snapped onto the fuel sending unit.
#26 |
This is the unit the pump sits in.
![]() The lines clip onto it. |
#27 |
1992 Lx
11.39@119.24
thats the pump at the bottom of that sending unit thing?
#28 |
Yeah you have a small curved rubber hose that sits in there. The metal lines you see at the top, thats where the fuel lines connect to.
#29 | |
1989 GT
KB 2.1L Flowzilla
Here is a good instuction for the pump change: PennMustangs - Fuel Pump Install |
Threads Similar to: What tools are required for a fuel pump install?
| Tools Required to Install Plenum/TB and Shifter | MyGT | 99-04 | 11 | July 18th, 2008 06:56 PM |
| Fuel Pump Install | ~C~ | 99-04 | 12 | July 7th, 2008 08:03 PM |
| fuel pump install | mustangjl | 99-04 | 0 | June 17th, 2008 06:46 PM |
| 310lph fuel pump install | zerofx150 | 99-04 | 0 | February 22nd, 2008 09:18 PM |
| Focus SVT Fuel Pump install | gsjohnson | 99-04 | 5 | September 16th, 2007 02:40 AM |
