What tools are required for a fuel pump install?
Old August 16th, 2008, 11:28 PM   #1
1992 Lx
11.39@119.24
just curious, doin it in about a week and a half
Old August 16th, 2008, 11:50 PM   #2
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
socket with long extension, flat head screw driver and a jack
an extra set of hands is nice too.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old August 16th, 2008, 11:51 PM   #3
1992 Lx
11.39@119.24
sweet me and my friend are gona do it, you know what size socket off the top of your head?
Old August 16th, 2008, 11:52 PM   #4
rattata johnson is an unknown quantity at this point
mmmmmmmm im gonna be your extra hands rrrrrrrrrrrrrrrrrrrrrattaaa!
Old August 16th, 2008, 11:58 PM   #5
Fast
Not off the top of my head, common size 9/16 - 1/2 something like that.
Sometimes those bolts get a little stuck. If you have air tools it will
be that much quicker.
Make sure you have a nice long extension for socket. At least a 12 incher.
It has to reach all the way up behind the gas tank.
God Help Us
Old August 17th, 2008, 12:07 AM   #6
1992 Lx
11.39@119.24
ohhhhh so we have the jack under the tank with a piece of wood or somethin then we gota unhook that junk from on top of the tank? is that what the extensions for?
Old August 17th, 2008, 02:56 AM   #7
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
Arctic Fox will become famous soon enough
1/2" for the straps that hold the tank in the car, and something smaller for the filler neck brace. Those are all the bolts that needs to be opened. Its easy job, just a bit messy
Originally Posted by FX4DTUF View Post
a camaro pulls up next to me and i think to my self what would jesus do at a time like this then it hits me he would launch it and power shift the shit out of it
Old August 17th, 2008, 02:08 PM   #8
Very easy job.........extension is for the bolts that hold the tank straps......
PeteAndersonRacing.com
Old August 17th, 2008, 02:36 PM   #9
1992 Lx
11.39@119.24
ohhhhh sweet thanks guys
Old August 17th, 2008, 03:12 PM   #10
we will just jack it up from the diff n00b. and stare into eachother's....................................... ...................cacks
Old August 17th, 2008, 06:21 PM   #11
shadowgames81's Avatar
87 Coupe
shadowgames81 will become famous soon enough
wow...anyways.....very simple job bro and easily a one man job. You can get it done in an hour. Common sizes for sockets so just pull out a few and the extension is a must.
Eats rice daily
Old August 17th, 2008, 08:24 PM   #12
94BLKGT is on a distinguished road
Yeah just try to make sure your tank is as close to empty as possible. Another thing i would go ahead and do your fuel filler neck grommit while your there. Oh and dont forget the fuel line tools. a brass punch and a hammer also
Old August 17th, 2008, 08:26 PM   #13
1992 Lx
11.39@119.24
gota link to this gromet? and what do you need fuel line tools and a brase punch for
Old August 17th, 2008, 08:27 PM   #14
nastia merc is on a distinguished road
fuel line tools are to probably disconnect the fuel lines goin to the tank.
....FUCK UP!
1986 Toyota corolla (AE86) yes, it's rear wheel drive
Old August 17th, 2008, 08:29 PM   #15
1992 Lx
11.39@119.24
why would you need a tool to disconnect a rubber fuel line? i know you need them at the fuel rails where the lines metal
Old August 17th, 2008, 08:30 PM   #16
Well i personally have always taken the lines off so i can take the whole pump assembly out of the take and out from under the car. Unless you wanna be tits up under the car with a old fuel pump dripping gas all over you. The brass punch and hammer is for the lock ring for the pump. You can use a screwdriver but just be careful you don't slip and cause a spark. Yeah let me grab it i just did a fuel pump install and trust me you have to move the tank so you end up putting a lot of stress on the grommet and its usually a good idea to replace it while your there.
Old August 17th, 2008, 08:32 PM   #17
1992 Lx
11.39@119.24
makes sense ill order the gromet ive heard about it going bad before, and cant we just unhook the rubber fuel lines from the tank and drop it?
Old August 17th, 2008, 08:33 PM   #18
Grommet # F4ZZ*9072*DA
Old August 17th, 2008, 08:34 PM   #19
1992 Lx
11.39@119.24
what sites that number from, summit?
Old August 17th, 2008, 08:35 PM   #20
Ford Mustang fuel filler neck grommet 1979 to 1997
Late model resto has it also
and MM
No you can't just unhook them
Threads Similar to: What tools are required for a fuel pump install?
Tools Required to Install Plenum/TB and Shifter MyGT 99-04 11 July 18th, 2008 06:56 PM
Fuel Pump Install ~C~ 99-04 12 July 7th, 2008 08:03 PM
fuel pump install mustangjl 99-04 0 June 17th, 2008 06:46 PM
310lph fuel pump install zerofx150 99-04 0 February 22nd, 2008 09:18 PM
Focus SVT Fuel Pump install gsjohnson 99-04 5 September 16th, 2007 02:40 AM
