#21 |
1989 Mustang LX
10.98@126.7 NA
I think the main argument here is being able to tinker and tune without being a rocket scientist. There is no way I or any other carb junkie can out think an EFI system, known fact. The appeal of a carb system is I can play with it and still be able to race or drive it after I mess around. I don't need some computer jock to tell me what's up. I beat up on EFI cars all the time and on occasion they return the favor, to each his own I guess. On a side note, I know at least 8 guys who have switched from EFI to carbed and they haven't switched back and are just as fast or faster then when they switched.
Never fast enough.
#22 |
The truth in the EFI vs. Carb debate is neither has an advantage in terms of power...
Power is limited by air flow, not fuel delivery (assuming you have an adequate fuel system). If an EFI system and carb system are both properly tuned and on intakes that flow the same amount of air, they will make almost identical power numbers. The advantage with EFI is you have electronic adjustment for operating conditions, sometimes that is worth the added expense, sometimes not. Carb intakes tend to have higher flow potential than most commonly used ford EFI intake manifolds, so if you are switching from a stock EFI manifold to a vic jr carb intake, no doubt you will make more power...should be common sense.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#23 |
Atomized
i agree with darrell on this one. I had a buddy that had an 84 gt and he had his carb tuned by two different reputable tuners he was unhappy with the result pulled an a9l and harness switched to efi had it tuned and his car was quicker and better drivability and he's been night and day happier since the switch. Not saying carbs suck i have some carb'd cars but I prefer efi all day.
#24 | |
#25 | |
89 GT
#26 | |
Tell your theory to some reputable EFI people and see what response you get.
#27 |
No it is not a good way at all but that is how Ford does it.
#28 | |
That is why I have been back and forth between using a 6000-6200 pill in my MSD and the stock one at 6250. I don't know which one I'd rather use. The stock is "softer" but I swear the engine ramps far past 6250. Ideally I'd be skilled enough to shift at 5800-6200 and not have to worry about it but I have not got that concept down in the lower gears. My peak power is right about 6K rpm and as the boost comes up, I typcially loose traction at about 4k in 1st and 2nd so it makes it a little tricky. I end up shifting too early, letting of the gas too much when it starts spinning, or I spin and instantly hit the limiter for a while. I'm sure some track time or tires that don't suck would solve my problem.
#29 | |
89 GT
#30 |
1993 Mustang
we'll find out when i come home from iraq.
i know i don't really know a whole lot about stangs yet but wouldn't the SCT Eliminator chip work for that?
#31 |
The last thing I had with a carb was a late 70's Grand Prix with a 301 and a quadrajunk. With the air cleaner off, the carb and engine sounded awesome. The car did not accelerate faster past half throttle but it did sound cool.
#32 |
Threads Similar to: is there a chip to just get rid of rev limiter?
| rev limiter | Iownastang | 5.0 Mustangs | 24 | June 8th, 2008 05:58 PM |
| Rev Limiter? | MamaStang | 2005 - 2010 | 22 | May 28th, 2008 08:53 AM |
| rev limiter | blakehunter316 | 5.0 Mustangs | 13 | February 22nd, 2008 11:04 AM |
| Rev Limiter ? | 92lx5oh | 5.0 Mustangs | 3 | March 19th, 2007 08:34 PM |
