Discussing putting my cam in. in the 5.0 Mustangs Forum. I had a buddy pull my old cam out for me. I want to put ...
Old August 19th, 2008, 07:10 PM   #1
1993 5.ohhhh
14.47 at 96 mph
putting my cam in.
I had a buddy pull my old cam out for me. I want to put my fcam in. I was told to buy some cam lube so I did. How should I put that on the cam. Just lube it up. Then slide it in? I was told just to put it in and be gentle on the cam bearings.
302 h/c/i
Old August 19th, 2008, 07:19 PM   #2
From the land of the wolverines
8t6gt's Avatar
1986 Mustang GT
Originally Posted by flattusmaximus78 View Post
I had a buddy pull out for me. I want to put my fcam in. I was told to buy some cam lube so I did. How should I put that in Just lube it up? Then slide it in? I was told just to put it in and be gentle
I just took out your usless words
Hurst Crew member #2 of 21
Co Founder of all crews.
Lee B and 8t6 the founders of crews
Proud member of the no southerners aloud SNOWMOBILE CLUB!
Old August 19th, 2008, 07:26 PM   #3
1993 Mustang GT
It's also easier to get leverage by putting a longer bolt in the front of the cam so you can grab that with your hand when it's almost in.
Bart
93 Black on Black GT
Kenne Bell S/C
Old August 19th, 2008, 07:52 PM   #4
1993 5.ohhhh
14.47 at 96 mph
Thansk for that tip man, it was a bitch cause I got your comment to late... but I see why it would work. I just need to find the torque specs for the two little bolts that going behind the timing sprocket. Then the main bolt.
302 h/c/i
Old August 19th, 2008, 09:32 PM   #5
93mustank's Avatar
Just use oil......
Stock 302,gt40p heads,exploder intake,afm n41 cam
Best 1/4..... 11.980 @112.588 mph...1.57 60ft
It goes good......
Threads Similar to: putting my cam in.
Putting in NAV Help! Ticket-Me-Yellow V6 Mustangs 13 December 6th, 2007 05:01 PM
Putting An 03 GT In My 96 JStang14 99-04 15 November 20th, 2007 12:19 AM
Putting In A V8? jeff V6 Mustangs 6 October 31st, 2006 01:54 AM
E cam or F cam horsepower and 1/4 mile time questions GreyGhost 5.0 Mustangs 1 August 21st, 2006 07:25 PM
Putting and 5.0 in my 94 3.8 Easy04_jm General Tech 2 April 25th, 2006 12:39 AM
