#61 |
1993 5.ohhhh
12.97 @140mph
Here is my exact set up, and I know... it's nothing special.
302 low compression pistons supposedly forged along with the rods Downs intake manifold Gt40p heads with e7 rockers f303 cam 30lb injectors v2 s-trim with a 3.33 pulley which I believe is 10 pounds. pmas 80mm maf 255 in the tank. I have an fmu, but I think I'm just ganna run an fpr instead. Like I said if I crack 400 I'll be happy. Id just like to trap around 114 plus. Think 400 is possible. And do I have to get the msd box to retard the timing before I go get the beast tuned?
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
#62 | |
Many people frown on using an FMU because it is a band-aid. That may be the case but it does work. I would suggest some type of retard if you are running over 6# on pump gas without some type of intercooling. I've never tried mine without it using at least 1 degree per pound. Maybe someone with more experience can speak about that.
#63 |
1993 5.ohhhh
12.97 @140mph
Well 30lb injectors is what I'm stuck with for now. I wasn't sure if it would be safe to make like 420 on those injectors, but you seem to be doing 470. So you would suggest that I run the fpr and the fmu, just crank the fuel pressure way up in boost, and have it sit a little bit higher for idle?
Say when I get the blower on and get it set up like that, how bad will I need a tune? or is it safe to drive around on. Assuming I get the msd box (which one exactly should I buy).
#64 |
get a 4:1 or 6:1 FMU with a bleeder valve fitting and a MSD 6 AL.
Using these 2 devices you can get an excellent tune. You're fuel pressure should be around 32-34 PSI at idle (38 vacuum line off regulator). The FMU will do the rest. A 6:1 will be very safe pulling 1.5 degrees per pound of boost. I have 30s with a 4:1 FMU and it does fine as far as A/F. I estimate well over 600 hp at the crank.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#65 |
1993 5.ohhhh
12.97 @140mph
I've got an fmu, It's a blue vortech one that came with my kit. I don't know the ratio.
#66 |
Take the 6 screws off the top and measure the size of the disc in there. They are interchangeable, so you can make any vortech FMU any ratio from 4:1 to 12:1. Post the size up and I'll tell you the ratio. Also, I have the disk for a 6:1 ratio I'll sell you cheap.
#67 |
1993 5.ohhhh
12.97 @140mph
Ok, I'll get to that in a little, but about this 6al box. Which one retards the boost. I'm checking out ebay, and most only have 2 step and rev limiters. Nothing with boost retard and the nob.
#68 |
Msd 6al-btm
#69 |
1993 5.ohhhh
12.97 @140mph
Well I pulled the disc out, I don't have anything to measure it with... lucky me. But its just a little over an inch from what I can tell.
#70 |
probably like 6:1 or 4:1
Threads Similar to: Got it dyno'd finally
| Finally Dyno'd The Paxton | killbee | 2005 - 2010 | 2 | June 21st, 2008 08:32 PM |
| Finally Dyno'd my v6 | D Rock | V6 Mustangs | 32 | March 19th, 2008 05:05 PM |
| Those who have dyno'd. | catchtheroadrunner | The Clubhouse | 4 | January 23rd, 2008 08:38 PM |
| I'm getting Dyno'd on the 9th! | Smoothgrandmama | 99-04 | 14 | January 4th, 2008 09:30 PM |
| Got Dyno'd Today | tjames | V6 Mustangs | 61 | December 12th, 2007 07:41 PM |
