Discussing build list in the 5.0 Mustangs Forum. Here is my build list so far. I'm planning on putting a motor from ...
Old August 19th, 2008, 10:11 PM   #1
AJSTANG's Avatar
1986 Mustang GT
build list
Here is my build list so far. I'm planning on putting a motor from fordstrokers putting out around 500hp. Let me now what else I need to add. The car will be for the street with the ocasional drag.
Crate engine with approx 500hp
TKO600 tranny with short throw shifter
cervini 2.5" or 4" hood
bbk long tubes and x pipe
3.73 gears
gear install kit
moser 28 spline axles
subframe connectors
rear upper and lower control arms
tubular k member
rims and tires
I already have a flowmaster catback exhaust and upgraded my front brakes some. I'll probably just get new drums for the back and ss lines all around. Let me know what else I should be looking to get. Is the anything else I need to do for suspension or cooling?
Old August 19th, 2008, 10:28 PM   #2
86_Notch's Avatar
1986 lx notch
10.78 @ 124.96
what are you gonna do for a fuel system ?
vids of my car
the raggedy car you hear is the nova, he's running open headers and it's drowning out my car
http://www.youtube.com/v/P3-7Oobydyo&hl=en
http://www.youtube.com/v/rmPPnfHZ9WA&hl=en
http://www.youtube.com/v/HcD354133Ac&hl=en
Old August 19th, 2008, 10:35 PM   #3
1993 Mustang GT
An aluminum rad. What about injectors, throttle body, MAF etc? or are you carbing it?
Bart
93 Black on Black GT
Kenne Bell S/C
Old August 19th, 2008, 10:57 PM   #4
AJSTANG's Avatar
1986 Mustang GT
I'm getting it carbed so all I should need is a pump. I forgot to add that to the list, I'm thinking a 190lph or 255lph. What about an ignition box? Is there a certain type I should get?
Old August 19th, 2008, 11:02 PM   #5
86_Notch's Avatar
1986 lx notch
10.78 @ 124.96
if it's going to be carbed then you need to run a new fuel system, the injected stuff isn't the best option ( yes you can regulate the stock stuff down but it's not the right way to do it )
vids of my car
Old August 19th, 2008, 11:17 PM   #6
AJSTANG's Avatar
1986 Mustang GT
What would a new fuel system include? I thought all I would need is a pump and regulator.
Old August 19th, 2008, 11:47 PM   #7
1986 LX
none yet
pump and regulator should do for fuel. and when buying the carb, dont go and get an 850 or anything. there are carb cfm calculators everywhere to check what size you should need. but probably nothing more than a 650. i suggest holley for the tunability.
and the aluminum radiator is a good one to add to the list as well as a good electric fan set up. taurus, escort, mark VIII, etc... but dont buy a flex a lite fan, they typically dont flow enough cfms. at least not the ones i have come accross.
Threads Similar to: build list
My new little list... jlaw98gt 96-98 23 April 10th, 2008 12:38 PM
The List!!!!!!! JASonic The Clubhouse 32 March 7th, 2008 12:45 AM
can we get a list Dennis-96GT The Clubhouse 19 November 11th, 2007 03:10 PM
list stupidstang V6 Mustangs 45 August 17th, 2007 06:34 PM
My wish list MustangMatt96GT 96-98 17 April 2nd, 2007 08:31 PM
