need vent help
LinkBack (1) Thread Tools
Old August 21st, 2008, 08:46 PM   1 links from elsewhere to this Post. Click to view. #1
91cobra5.0's Avatar
94 GT
need vent help
no matter what i turn the dial to only the defroster works, i replaced he controls and it still doesnt work, what sensor do you guys think i am having trouble with if there are any sensors?
94 GT - Deep Forest Green
Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block
Old August 21st, 2008, 08:48 PM   #2
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 7 reviews
I'm pretty sure its vacuum controlled.... So make sure the vacuum line in the engine compartment is still hooked up.
TT Build in progress.......
Old August 21st, 2008, 09:06 PM   #3
91cobra5.0's Avatar
94 GT
would ne one happen to have a picture of the line im lookin for?
Old August 21st, 2008, 09:07 PM   #4
The vacuum line will run along the fire wall...... Goes from the driver side the pass side......
PeteAndersonRacing.com
Old August 21st, 2008, 09:12 PM   #5
91cobra5.0's Avatar
94 GT
theres a few that do that, is it a skinny or a fatty?
Old August 21st, 2008, 09:20 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
It is the little hard plastic one that runs from the vac tee along the firewall and goes in on the upper part of the passenger side buy the hood hinge. I believe there is also a little round check valve on it about an inch in diameter. I'm describing this from memory on my non stock Mustang so stock my be a little different like it may be connected to the vac tree that hangs near the throttle body instead. Those hard plastic lines get brittle over time and crack easliy. I had the same problem a few weeks ago. There is also a vac tree inside the car with colored lines in it, again, from limited memory and I may be confused but it should be near the passenger side under the glove box?.
Old August 21st, 2008, 09:32 PM   #7
91cobra5.0's Avatar
94 GT
yea that little tree thing you are talking about i know those line broke, but i dont know were to find them does anyone?
Old August 21st, 2008, 09:37 PM   #8
91cobra5.0's Avatar
94 GT
will generic vaccum lines work and if so does anyone have a diagram?
Old August 21st, 2008, 09:44 PM   #9
nolife's Avatar
91GT, 88GT, 02GT
You can slide a regular vac line over the hard plastic ones.
Some diagrams compliments of tmoss.
http://www.veryuseful.com/mustang/te...m_controls.gif
http://www.veryuseful.com/mustang/te...uumDiagram.jpg
Old August 21st, 2008, 09:57 PM   #10
91cobra5.0's Avatar
94 GT
thats confusing were are the lines that run to this
Old August 21st, 2008, 10:28 PM   #11
nolife's Avatar
91GT, 88GT, 02GT
Its dark now but if no one responds by tomorrow, I can look at my other Mustang and trace them out.
Old August 21st, 2008, 10:34 PM   #12
The one pictured has nothing to do with it
Old August 22nd, 2008, 08:09 AM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The vacuum line in the picture looks like an emissions line from the passenger side of the engine compartment.
Old August 22nd, 2008, 11:13 AM   #14
91cobra5.0's Avatar
94 GT
thats were it came from but i had no idea were it is for
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/85596-need-vent-help.html
need vent help This thread Pingback August 21st, 2008 09:45 PM
Threads Similar to: need vent help
Vent itschristorres8 The Clubhouse 9 March 27th, 2008 01:02 AM
Vent Cricket The Clubhouse 17 February 29th, 2008 07:10 PM
I need to vent.... TurboLX The Clubhouse 95 September 25th, 2007 01:10 AM
I just need to vent. . . 707Stang The Clubhouse 38 August 7th, 2007 04:37 PM
A/C Vent D-Brow V6 Mustangs 5 June 26th, 2007 03:06 PM
