1986 lx notch
9.98 @ 135
Braided tranny lines ????
i want to replace the hard transmission cooler lines with braided lines but what size should i use # 4 or # 6 ? btw i've got a performance automatic c 4 if that matters
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
Use -6.
1986 lx notch
9.98 @ 135
thanks
how much of it should you need to do this im ordering things right now.. not sure how much length i need??? thnx alot
15 feet should get the job done and give you some extra to boot.
is braided better to use or push lock?
1987 ford mustang gt
well see when shes done
i like the braided because of its look but its your choice,pushlock also works as well they will both get the job done.
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
STOP!!!!! you need to be 100% sure that you are using line that is specified for transmission fluid... transmission fluid will tear up normal rubber line... so whenever you order your line, be sure to tell them that it's for an atf application
We are talking braided line, not auto parts store rubber hose. Its good for transmission fluid, gas, diesel, engine oil, gear oil, coolant and good to 1000 psi.
braided or not, it's still rubber inside... as long as the manufacturer says it's good for hydraulic fluid, then fine, i'm just making sure youre not asking for trouble...
Show me a braided hose that is not good for transmission fluid, gas, diesel, engine oil, gear oil, coolant and good to 1000 psi......
Threads Similar to: Braided tranny lines ????
| TRanny lines | ByPopularDemand | V6 Mustangs | 4 | April 16th, 2008 07:58 PM |
| Braided lines / Brake pads | Wado | 2005 - 2010 | 22 | October 11th, 2007 11:04 PM |
| Braided Fuel Lines | gotboost562 | 5.0 Mustangs | 11 | October 11th, 2007 04:01 PM |
| stainless steel braided hose | juan310 | V6 Mustangs | 0 | September 9th, 2007 08:55 PM |
| Rear Braided Brake Hoses | WAR-PARTY | 99-04 | 1 | February 13th, 2007 08:27 PM |
