19lb calibration w/ 24lb injectors?
LinkBack (1) Thread Tools
Old August 22nd, 2008, 03:36 PM   1 links from elsewhere to this Post. Click to view. #1
Frankenstang is on a distinguished road
what kinda problem would i have if i used a set of 24lb injectors with a 19lb calibrated Maf? i have a set of both injectors just wanted to know if there would be any pros/cons to stepping up to the 24lbs with out getting a new MAF?
thanks in advance
Old August 22nd, 2008, 03:38 PM   #2
It will be all cons....good luck getting it to run right
PeteAndersonRacing.com
Old August 22nd, 2008, 05:47 PM   #3
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
your car will run too rich.. the 24# injectors flow approximately 20% more fuel...
not exacty a good idea
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old August 23rd, 2008, 09:16 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You won't gain any horsepower if that is what you are asking. Unless you are making over 300hp right now and your engine is starving for fuel. And like the others said, it will run like shit.
Old August 23rd, 2008, 10:21 AM   #5
i appreciate the help fellas.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/85721-19lb-calibration-w-24lb-injectors.html
19lb calibration w/ 24lb injectors? This thread Refback August 23rd, 2008 10:57 AM
Threads Similar to: 19lb calibration w/ 24lb injectors?
Max hp with 19lb injectors. 95blackbeauty 94-95 12 April 17th, 2008 08:48 PM
19lb injectors big enough with trickflow h/c/i kit? 93hatch 5.0 Mustangs 22 January 16th, 2008 10:21 AM
