Discussing clutch problem in the 5.0 Mustangs Forum. installed a new clutch kit and throw out bearing ,pedal is still spongy,hard to ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
clutch problemplease help thank you wheels are spinning and no where to go. |
If so place your foot under the clutch pedal and pull it towards you, then push it to floor, if teeth aren't messed up on quadrant it should make some adjustment. May need to do this a couple of times. Check quadrant for cracks or broken pieces, if it looks okay you shouldn't have any problems with. Just sounds like clutch isn't adjusted up enough. If you replace the cable get a firewall adjustable one, I put in a FRPP replacement that adjusts at the clutch lever, and it is a PITA!!, especially as the cable stretch's. Good luck |
thanks !!! |
does anyone know if this is easy to install and is it basic stuff. |
If it's a stock quadrant there should be some teeth on it, and a little cam like rocker(about an inch or 2 long) with teeth that is spring loaded that locks into these teeth. It can only lock in one direction, try this link, not very clear but might help. http://www.fordracingparts.com/downl...-7553-B302.pdf |
Threads Similar to: clutch problem
| clutch problem | rob madison | 96-98 | 5 | October 26th, 2007 11:06 AM |
| problem with clutch. | mike96gt | 96-98 | 2 | September 21st, 2007 04:33 PM |
| Clutch problem for 88 5.0 306 | shawn91stang | 5.0 Mustangs | 8 | January 7th, 2007 03:34 AM |
| clutch problem in a 92' 5.0 | red_baron243 | 5.0 Mustangs | 5 | January 7th, 2007 02:38 AM |
| clutch problem in a 92' 5.0 | red_baron243 | 5.0 Mustangs | 0 | January 5th, 2007 10:18 PM |
