Need Help Asap!!
OK i have an 91 Mustang GT i just put on an trickflow upper and lower intake, 70mm throttle body, bbk cold air intake, pro-flow 75mm mass air flow, 24lb injectors. And it ran pretty good after i finish it all and could tell the difference from when it was stock. But just the other day i put in some 3.73 gears in and now its having problems with it starting sometimes, sometimes the fuel pump want kick off when the key is turned others it will, then sometimes when i try to start it up it seems like its jumping time so i go and mess with the distributor to time it and then it'll run decent again but then after driving it for a little bit it'll do the same thing, my check engine light will come on and then it'll stall and do the same thing all over again it wont start and if it starts it'll back fire then just stall out. But tonight it happen it stalled and then i try to start to start it and it started for a second and when i gave it gas it would just back fire then stall but then i waited like 30seconds to start it again it started right up like nothing happen. I am clueless does anyone have an ideal whats going on or what i should do ? Let me know asap if you could, would really like to get this fix. Thank you.
If you could message me on AIM or something that would be great. Thanks |
Oh yeah and i also have an warbro high performance fuel pump also if that helps any. I didnt put it in the car came with it when i first got it and never had a problem with it til i did all this stuff with the car.
#3 | |
I Post Entirely Gay Too Much
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
almoust sounds like 180 out on the distributor, other than that check your vacume lines
did you make sure you have the dist marked when you pulled it out? also check firing order
![]() Last edited by dr.gonzo!; August 23rd, 2008 at 06:21 AM. |
See that happen before when i first put all the intake on and evrything and i re timed it right after that but then it just started to act all up after the gears.. I was told something about my timing belt and the gears in it might be wore out ? That for the reason it jumping time ?
#5 | |
The 3.73 gears would have nothing to do with the engine starting/backfiring
but after you put the intake on, if you didnt mark where you pulled your dist at before you pulled it out and just slapped it back in, the engine will not know what cyl to fire. so it will run like shit.
![]() Last edited by dr.gonzo!; August 23rd, 2008 at 06:27 AM. |
Yeah, i have the book on the mustang so everything was done right when i retimed it. But just everything started to happen after i put the gears in. And What about that timing belt ? Because i was told it might be wore or something and its not holding up and i should get a new one so i was thinking about going to get one this morning but if doesnt sound like i shouldnt get one i dont wanna get one. And do the caps have any sort of gaskets on it to hold on it nice and tight? Because its kinda lose too just going up and down on the cap.
#7 | |
No the cap should not move. make sure you have both clamps on it.
is it just tha cap or the whole distib that moves?
Yeah i made sure the clamps were both on. And its just the cap like if you were trying to rock it back and forward. But im going to get a new one anyways because i got shocked today when i was trying to time it. But with the fuel pump like when it sometimes doesn't turn off well i know its always running but when you turn the key and it'll make that noise for a second and stop but it just keeps going and from the relay it makes like a spark noise ? I dont get it i've never had a problem like this before.
Sounds like the ignition module might be going bad. Gremlins like this can be hard to find.
So it might not be my timing at all ? Because im gonna go get a new timing belt but if i dont need it i dont wanna go get one.
#11 | |
Sounds like ignition module to me also.........or the PIP sensor
PeteAndersonRacing.com |
your car has a timing chain, id vote ignition module.
your gears wouldnt cause any issues like this, but if your timing it and then tightening it down correctly, it shouldnt be any issue with the timing. |
Alright thanks i just went in and took my module in and it tested bad when it got hot so im bout to put that on and see what it does. Thanks
There anyone on here close in michigan that tunes cars for kinda cheap ?
There are all kinds of places in Michigan that tune cars. I don't know what your definition of cheap is so I can't answer that. You get what you pay for.
#16 | |
Yeah true but i just dont any alot right now. But im having another problem with my car. Earliar when i got on it my check engine light came on and then it started to run like shit and it wanted to bog and stall. I have no clue what it is ? I was thinking maybe im not getting enough fuel but that wouldnt make my check engine light come on... ?
#17 | |
Threads Similar to: Need Help Asap!!
| need help asap | 91cobra5.0 | 5.0 Mustangs | 8 | April 16th, 2008 08:20 PM |
| help asap | silver_96 | 96-98 | 33 | March 5th, 2008 12:58 AM |
| help asap please | WeCircleTheProblem | V6 Mustangs | 14 | August 16th, 2007 07:21 PM |
| NEED HELP ASAP!! | 92stang0802 | 2.3 Mustangs | 53 | July 5th, 2007 01:03 PM |
| NEED HELP ASAP!! | VetteC5RFrEak | 5.0 Mustangs | 0 | August 3rd, 2006 03:01 AM |
