Discussing supercharging my 302 help please in the 5.0 Mustangs Forum. needed to know parts i need to upgrade to support a supercharger and not blow ...
Old August 24th, 2008, 10:07 PM   #1
Thumbs down
needed to know parts i need to upgrade to support a supercharger and not blow my engine IE. pistons rods? thanks
Old August 24th, 2008, 10:09 PM   #2
1989 LX Vert - 1993 Notch
Fast
fuel pump, good MAF, good injectors and good safe tune.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old August 24th, 2008, 10:09 PM   #3
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
you can run a blower on stock internals bro.. just keep the boost low.
Old August 24th, 2008, 10:10 PM   #4
1986 Mustang GT
the stock internals are just as long as you're going to run low boost i.e. 6-8 lbs. if you start upping the boost then you're definately going to want to have stronger internals. You will probably need larger injectors also
Old August 24th, 2008, 10:20 PM   #5
91 mustang lx coupe
way too slow
my friend just built a 302 car with a powerdyne bd11a all he did was throw on a good set of heads, he's only running 24 lb/hr injectors with a 190lph pump and adjustable regulator. let me tell you though, that car will smoke the tires well into third...
Old August 25th, 2008, 12:20 PM   #6
nolife's Avatar
No one can give specific advice for what you "need" or what is logical until they know a HP level you are aiming for. A ball park HP estimate is needed first and is based on the final components on the engine and the boost level you plan on running.
A car running 6# boost on a stock engine will need a lot less than a car with a high revving 347 at 10# boost.
1991 GT - Original owner, all stock
1988 GT - The project car
Old August 25th, 2008, 12:58 PM   #7
awesome thinks for all the advice im shooting for 400+ hp
Threads Similar to: supercharging my 302 help please
Supercharging? plove71387 V6 Mustangs 25 December 3rd, 2007 11:08 PM
Need Help With Supercharging 07 GT project07GT 2005+ 31 November 16th, 2007 02:32 PM
Supercharging a 302 95blueGT 94-95 4 May 28th, 2007 04:06 PM
Supercharging scxc15 Poweradders 12 March 19th, 2007 08:26 PM
Weight of Dart sportsman 302 compared to stock 302 painfully slow 5.0 Mustangs 3 February 23rd, 2007 05:47 PM
