1991 mustang 5.0
So my car overheated..
This is the second time this has happened. The previous owner bypassed the Heater core but used a crappy fitting to connect the 2 hoses. It popped open and I leaked out all my coolant and I had to drive the car home like that with the thermostat at 270.. It happened again today and I drove 30 minutes with it like that. I finally replaced the hoses with clamps and such so it won't happen again. But my question is, when I had to drive the car home, did I hurt the engine at all? The thermo was pegged at 260-270 the whole way...
wow... that's one of the dumbest things you can do.... sorry, not trying to be an ass, but seriously... fix the heater hose issue and drive it... if it drives ok you MAY have gotten lucky.. but most of the time you'll know right away when it's messed up...
1991 mustang 5.0
Well i live in the middle of nowhere and work 40 miles away, I really didn't have much of a choice but to drive it home. I fixed the hose and replaced all the coolant and it seems to run fine. Just wondering if there was anything I would have to expect to fix.
Hey, damn bro, like "thatdavidkid" said, that was not a very wise decision. I understand you might of not had a choice. But you could have parked it somewhere decent, called a buddy, picked up some parts and went and fixed it. Pegged 260-270. Thats insane and yea you could have done some serious damage. You might of ended up lucky, but normally things would def blow due to the extreme heat. Consider your self lucky. Next time give your mustang the common courtesy and pull over and shut her down.
PaT #06 |
1989 Mustang LX
10.98@126.7 NA
Tons of things that could have happened. Time will tell you if anything was damaged. If you know that you can get stranded in the middle of no where, better come up with some emergency supplies like extra oil, trans fluid, fix a flat, water / coolant, tools, electrical tape and a good cell phone.
Never fast enough.
1991 mustang 5.0
Everyone was at work though and my dad already saved me because I ran out of gas that day. I pulled over and let it chill for a half hour but I had to get to autoozne which was by my house. Before I did that I got home and let it cool off and put new water in it. Then I went to autozone and replaced everything so I don't think it will happen again. I blame the previos owner for mexican rigging it lol... But idk I guess time will tell if anything is wrong. It seems fine though
I Poop Entirely Way Too Much
Blown 03 GT
^ and AAA. You may be lucky but Thats def not a good thing man.
1991 mustang 5.0
I hope I got lucky.. I'm hoping my thermo doesn't work right haha
you might be further ahead to replace your thermostat, its only 8 bucks that kinda temps might of smoked it.
12.8@103... stock motor
11.8@113...150 shot
1991 mustang 5.0
Honestly it seems to run better now lol
your lucky you didnt blow your head gaskets but i can tell you that you probally warped the heads alittle.it might be so slight that its ok for now.
my car runs on corn bitches ![]() Joey |
smell your oil... if it smells like gas, you cracked a ring or something... and definately replace the thermostat... if you dont, i will go into your next thread titled "i did it again" and say I TOLD YOU SO"....
1991 mustang 5.0
Why would I make a new thread? The reason it overheated is because the heater bypass had a crappy fitting and came undone and leaked all my coolant out. I fixed it and drives just fine. Hottest it's gotten so far is maybe 150.
1991 mustang 5.0
dont ever let that engine get to 270 again, next time just shut it off and let it cool.
1991 mustang 5.0
It runs better than when I first got it though lol. It would run rough and lean in the upper rpms under WOT. And I remember the crappy fitting leaking, and I recall my engine running hotter then so I think that's what was making it run crappy.
well good, ya its not good for a engine to get to that temp
1991 mustang 5.0
Threads Similar to: So my car overheated..
| If i put lowering springs on my car, will it lower my car? | mikevm78 | The Clubhouse | 6 | April 3rd, 2008 07:07 PM |
| Overheated | hudini | 99-04 | 1 | September 29th, 2007 09:36 PM |
| overheated engine? | 94stallion | V6 Mustangs | 3 | March 24th, 2007 01:08 PM |
| mustang getting overheated? How hot is normal? | piano4eva11382 | V6 Mustangs | 13 | February 20th, 2007 09:52 AM |
| Help! (Overheated And Not Running Right) | Nor57 | General Tech | 1 | June 25th, 2006 03:18 PM |
