roll cage
LinkBack (1) Thread Tools
Old August 27th, 2008, 05:35 PM   1 links from elsewhere to this Post. Click to view. #1
1BADSTANG's Avatar
1BADSTANG is on a distinguished road
roll cage
How much work is it (and money) to get a roll cage in a 88 5.0? My car will be high 11's low 12's, and its got subframe connectors and a strut tower brace, lake wood 50/50's, nitto 555rs, so traction/stability is pretty good but i think i want a roll cage in their. I want to keep the back seats, and i dont mind having to help people get in (lifting them over the bar or whatever it takes). What will it do for me in terms of stability? how much do they weigh? thanks a lot..
Old August 27th, 2008, 06:10 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You won't need a roll bar until you go 11.49 or faster. A roll bar or cage will stiffen the car up alot. You are looking at adding about 100 pounds to the car with a mild steel 8 point roll bar. Chromoly will be about 25% lighter. How easy or hard it is to install depends on how good at metal fabrication you are and how good you can weld pipe. Welding pipe is alot different than welding two pieces of flat steel together.
Old August 27th, 2008, 06:13 PM   #3
12.8@103... stock motor
11.8@113...150 shot
R0B0T can only hope to improve
wolfe sells a chromoly cage for about 600 bucks.
check them out.
and yes, it is a lot of work and you will pay more for labor than for the roll cage itself if you can't weld it yourself.
also, do you want to be nhra certified?
Old August 27th, 2008, 08:10 PM   #4
1BADSTANG's Avatar
No i really want to do it for the right to say "i have a roll cage" Plus with the nitrous and hci im sure i will be seeing tens eventually.. after a lot more work
Old August 27th, 2008, 08:39 PM   #5
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
i bought an S & W roll bar and it fit really nice, the bar came notched and it's bent to clear the back seat. my boy and i bought ours together so we got a small discount plus we used his company truck ( and gas ) to pick them up so we didn't pay shipping . My other buddy came over to my house and we ( he ) welded the bar in my car in less then a day. so to surmise ... i really like the S & W bar. btw a buddy of mine got a competition engineering bar and it required a lot of massaging to get it to fit right
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old August 27th, 2008, 09:07 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
Do you remember which one you got? I see a moly 8 point for $400.
Old August 27th, 2008, 09:40 PM   #7
notched306 is on a distinguished road
Send a message via AIM to notched306
stay away from the comp enginering cages,i got one of those and the only thing that was made for the car was the main hoop,everything else was cut to fit.it took me all fuckn day to put it in.i will never put that cage in again.maximum motorsports has a really nice 6 point cage.we put one in my freind capri and it took us 3 hours.welding and everything
my car runs on corn bitches
Joey
Old August 27th, 2008, 09:43 PM   #8
86_Notch's Avatar
1986 lx notch
9.98 @ 135
mild steel
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/86482-roll-cage.html
roll cage This thread Refback August 28th, 2008 10:19 AM
Threads Similar to: roll cage
roll cage sixpack 5.0 Mustangs 0 June 23rd, 2008 06:24 PM
Roll cage??? flamed 98 gt 5.0 Mustangs 25 February 15th, 2008 05:13 PM
roll cage install ttop5.0 Drag 12 September 7th, 2007 04:31 PM
05-07 mustang roll cage Norse1974 2005 - 2010 6 April 28th, 2007 01:51 PM
what speed do you need a roll cage? jessy_is_rad Drag 12 April 8th, 2007 02:09 AM
