block heater plug?
Old November 28th, 2006, 10:21 PM   #1
slingblade05 is on a distinguished road
block heater plug?
does anyone know if and where the block heater plug is on a 1990, 302 engine and also where are the frost plugs located?
one more thing, i only had water in my engine ( slaps myself in the head) and it froze over night?
uh oh!
Old November 29th, 2006, 11:36 PM   #2
83 5.0's Avatar
83 5.0 is on a distinguished road
Ouch! hopefully it was frozen solid.
Look on the side of the block up near the motor mount position and you will see a couple of round disk shaped plugs about 1.5-2" round. These are the frost plugs (or casting/core plugs when casting). Look for a power cord going to one or an electrical terminal, this would be your block heater if you have one. Could be on either side.
As for damage from the freeze up: look for water in oil, or vice versa. Run engine and just keep an eye on these things, you will know soon enough after putting on some miles. Look for leaks around frost plugs in case one pushed out a bit.
Good Luck
Old November 29th, 2006, 11:37 PM   #3
ok thanks,that helps a bunch
Old November 30th, 2006, 08:56 PM   #4
83 5.0's Avatar
Sorry meant to say hope it WASN"T frozen solid, but hope no further problems
Old December 4th, 2006, 01:24 AM   #5
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
Just a general idea
http://z.about.com/d/autorepair/1/0/Z/s/00000105.gif
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Threads Similar to: block heater plug?
AC & Heater now that it is winter, my heater doesn't wor Kingcater 5.0 Mustangs 13 January 22nd, 2008 01:33 AM
Boss block or Dart block??? JONJON 5.0 Mustangs 48 November 6th, 2007 10:37 AM
short block differs from a long block how? mustangfox9091 5.0 Mustangs 35 September 26th, 2007 11:57 PM
block coolant drain plug Buttaz V6 Mustangs 5 July 24th, 2007 06:34 PM
Stock Cobra Block and GT Block the same?? bbrewer03 96-98 2 August 26th, 2006 02:31 PM
