Which Intake ?
Looking around for a good intake to step it up a notch. Which intake ?
BBK SS-5001 EdelbrockTrick flow (TFS-51511001) (515000001) Please Help ? Thanks |
1992 Lx
11.39@119.24
dont get the bbk piece of shit
1989 Mustang GT
![]() Ported Saleen Vortech Intake BBK 70mm t/b,BBK CAI,BBK Reg,BBK 255 Fuel Pump Hooker Super Comp Long-tube Headers Fcam Ported Motorsport J302 Heads 30# Injectors 1.6rr 80mm Mass Air 4:11 gears |
BBK
Why Not ? What should I choose ?
1989 Mustang GT
I'm partial to Trick Flow but theres always Edelbrock or Holley SystemMax, GT40, Cobra list goes on just stay away from BBk intakes.
How much hp more has your given you ?
1989 Mustang GT
Won't see a big diff till I get better heads.
93 GT N/A 302 H/C/I
6.73@101.7--- 10.59@126.06
1. What's the combo?
2. Intended useage?
N/A 302 Pushrod Power ![]() |
what is the promblem with bbk intake manifolds? i have a bbke cold air are those bad too?
![]() FORD = FOUND ON ROAD DOMINATING www.myspace.com/stangdevin |
#10 | |
1992 Lx
11.39@119.24
no i have a mac cai, same shit as the bbk, its their ssi or whatever intake mani thats a pos
#11 | |
i was gonna get this one BBK 5001 - BBK 5.0L SSI-Series Intake Manifold - JEGS or this one BBK 5008 - BBK 5.0L SSI-R Series Intake Manifold - JEGS so it would be a bad idea to get one of these?
#12 | |
1992 Lx
11.39@119.24
theres much beter intake manis for the the money dude, its been proven just look it up, stick with something proven, like trickflow, holley systemax, etc or go the cheap route like me and get an explorer intake mani if you never plan on makin huge numbers
alright dude thax i will have to look around then
trickflow i think is the better of the intakes.... and as far as hp.... you need to replace your heads to get a substantial amount lol
#15 | |
1992 Lx
11.39@119.24
he already has heads
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
EDELBROCK PERFORMER/RPM INTAKE
or TRICK FLOW STREET HEAT INTAKE Both are great, trick flow looks better but the edelbrock has more HP. If you ever need the gaskets for the upper trick flow intake let me know. I have 3 brand new ones in a box at my house. PaT #06 |
I have ran every intake mentioned here and probably 2-4 others. The BBK is junk period. The rest of the ones mentioned all have their qualities and I like them all. However for the gain and price for a street car I would highly recommend the Typhoon EFI upper and lower made by Professional Products. You can find the Satin version for $300 or less for both pieces. It will be a little buggery in the casting but nothing you can't knock off with a dremel in a few minutes and they perform on a dynojet 248 just as well as several of the above mentioned.
I have a 90 Gt here with Edelbrock Performer heads, Typhoon intake, long tube headers and a 200 shot running low 6's in the 1/8th. It has several other mods but that should give you an idea of it's potential. I also have a 94 Gt with a junky Powerdyne S/C, Edelbrock heads and the Typhoon intake making 459 @ the rear tires so they flow just fine. Professional Products Online
You haven't failed until you stop trying. |
Third try.......
#20 | |
Threads Similar to: Which Intake ?
| short ram intake or cold air intake????? j/w | Stangbro8994 | V6 Mustangs | 32 | September 18th, 2008 08:20 PM |
| Aftermarket intake vs Cobra intake... | Brent Russell | 5.0 Mustangs | 11 | April 27th, 2008 10:35 PM |
| 95' Mustang 5.0 HO intake swap for 93 cobra intake... | stang9587 | 5.0 Mustangs | 1 | April 3rd, 2007 05:20 AM |
| Need help using a 5.0 upper intake on a 5.8 lower intake | Washington5.0 | 5.0 Mustangs | 4 | March 9th, 2007 01:54 AM |
