Spring compressor tool
Old September 1st, 2008, 08:55 PM   #1
Jojogunne's Avatar
1984 GT
13.21@104.61
Jojogunne is on a distinguished road
Could someone send me a picture or part # for the tool they use to change their front springs with.
I have changed my springs and the tool I use works barely. I am trying to get my car set up for the strip.
jjg
Eibach Sportsline, Mac, Moroso,Comp Cams,PRW roller rockers, and no money left over.
Old September 1st, 2008, 09:26 PM   #2
91 mustang lx coupe
way too slow
thatdavidkid is on a distinguished road
Send a message via AIM to thatdavidkid Send a message via Yahoo to thatdavidkid
on a fox, the front spring "tool" i use especially once you lower the car is a pry bar... unbolt the c/c plate or upper strut bolt, unbolt the swaybar mount and the control arm will lower enough to get springs (anything shorter than stock) out
Old September 2nd, 2008, 02:24 AM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
you can get the spring out without the tool.
Old September 7th, 2008, 10:10 AM   #4
BigBlockFairlane's Avatar
BigBlockFairlane is on a distinguished road
How do you get it back in? Which tool?
http://i95.photobucket.com/albums/l148/supercobrajet/Boostednotch.jpg
Old September 7th, 2008, 12:56 PM   #5
Jojogunne's Avatar
1984 GT
13.21@104.61
Thanks for you input,
I used the crowbar. With out a lift is was quite difficult. I wouldn't recommend that method for Eibach Drag Launch Springs .... I WOULD NOT recommend those springs anyway. Those were the ones I replaced with springs from a 4cyl. and I had to cut one coil to get the car to sit properly.
Threads Similar to: Spring compressor tool
Emergency/Parking Brake Spring Compressor? Garhfer 99-04 9 August 29th, 2011 01:10 AM
A/c compressor 2000Mustang V6 Mustangs 10 August 26th, 2008 08:34 AM
ac compressor JoshC! 5.0 Mustangs 1 July 21st, 2008 04:49 PM
Need help......Spring lock fuel fitting tool?????? Bossman Modular Mustangs 7 January 25th, 2007 09:58 AM
