car lean..need to trick it to run rich - Page 2
Old December 7th, 2006, 11:33 PM   #21
chadjones99's Avatar
chadjones99 is on a distinguished road
yes I have a battery disconnect switch on my car for theft reason's and the fact that I don't drive it very much and like having the battery disconnect so I know it is not being drained...
So I will disconnect the O2's and plug holes, turn battery off should reset computer , and that should do the trick correct ?
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion
Old December 8th, 2006, 12:08 AM   #22
TENGRAM is on a distinguished road
yep.
89 GT t5 3.73
www.my5oh.com/
Old December 8th, 2006, 08:26 PM   #23
no O2
ok, i did it.. so far so good... it does not have that low power band weakness it had before
Old December 8th, 2006, 09:44 PM   #24
Re: no O2
cool, glad to hear it. it helped with my lower rpm troubles a little bit as well, plus it seems like throttle response is improved.
89 GT t5 3.73
www.my5oh.com/
Old December 8th, 2006, 10:45 PM   #25
ya i think they run better like this. might hurt fuel milage , but thats not why i have this car.. will it also affect timimg ?
Old December 8th, 2006, 10:55 PM   #26
nope, as far as i know it won't. and yeah, when i see people complain about fuel mileage in their stangs it makes me laugh...i guess they shoulda bought a 4-pot
89 GT t5 3.73
www.my5oh.com/
Threads Similar to: car lean..need to trick it to run rich
lean really lean plaese help 331 stroker stangzilla 331 94-95 8 January 30th, 2010 07:58 PM
lean patwrecked 5.0 Mustangs 4 September 10th, 2007 10:59 PM
Lean! Clayhistorian V6 Mustangs 5 April 24th, 2007 12:07 PM
Fuel Problems Burning Rich / Burning Lean Steves LX 5.0 Mustangs 5 March 21st, 2007 10:46 PM
Difference between running rich/lean 1996gt 96-98 3 January 29th, 2007 04:30 PM
