car lean..need to trick it to run rich
Old November 29th, 2006, 08:43 PM   #1
chadjones99's Avatar
chadjones99 is on a distinguished road
Hello, what is the easiest way to trick my 86 gt 5.0 (with MAF CONV) to run rich all the time.
I had a problem with my O2's and they are hooked up, but for what ever reason my car is running lean in till about 3/4 throttle . then it goes full rich and runs great. I am not worried about mileage I just want it to run rich all the time. as this is safer in till I find out why it is running lean.
I have heard that jumping a wire or doing a disconnect on the water temp wire will default it to run rich, what about just unplugging the O2 plugs or do I have to jumper them to make it think it is lean and to go rich ?
thanks
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion
Old November 29th, 2006, 09:50 PM   #2
stang fanatic's Avatar
stang fanatic is on a distinguished road
break your intake temp sensor so it reads a default cold reading
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old November 29th, 2006, 09:51 PM   #3
have you hooked up a reader to see what codes you might have stored nd what sensors are reading? if the intake is reading hot, itll lean you out
Old November 29th, 2006, 09:52 PM   #4
HMUSN's Avatar
iTrader: 9 reviews
just drop some 42's in.
you'll never run lean again
Old November 29th, 2006, 10:05 PM   #5
no codes on intake just left bank. i had 24 in but have dropped back to the 19 lb ers
so unhook the intake sensor ? pull it out , etc
Old November 29th, 2006, 10:31 PM   #6
so do i pull it out.. or just unplug it ? also what will happen if i unplug my o2 sensors ?
Old November 30th, 2006, 02:22 AM   #7
TENGRAM is on a distinguished road
...what code did you get? did you do the cylinder balance test? possible you are just running lean on one cylinder...if thats the case i would suspect the injector is stuck closed. really its gonna be a good idea to figure out whats actually the problem, rather than trying to trick the ECM...if it is an injector stuck, "breaking" your ACT won't fix it.
89 GT t5 3.73
www.my5oh.com/
Old November 30th, 2006, 11:06 PM   #8
balance test ran fine.... and i have tested all injectors my self by hand with a 9volt batt..they work
Old December 4th, 2006, 01:33 AM   #9
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
Can I ask why you did that?
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old December 4th, 2006, 01:36 AM   #10
good question.
chad, if you didn't recalibrate your maf for the 19lbers than that is likely your problem. that would definitely cause it to run lean
89 GT t5 3.73
www.my5oh.com/
Old December 4th, 2006, 01:36 AM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Do you have the right Mass Air Sensor for your injectors?
Old December 4th, 2006, 01:10 PM   #12
I have a C&L Mass Air meter and both tubes for it
the 19lb cal tube and the 24 lb cal tube. it does run right as far as that goes because one of the times i did forget to put the other tube in and it ran like crape intill i put the right one in
Old December 4th, 2006, 03:17 PM   #13
if you want to verify that you have the right tube in (because they're different for 73mm vs 76mm) check THIS CHART
89 GT t5 3.73
www.my5oh.com/
Old December 4th, 2006, 09:48 PM   #14
yes u have the right tube .. and by the way cool chart could come in handy.
the car runs good.. i just think it is running a little lean and would like to trick it out to run rich , just so i could test it
thanks
all
Old December 7th, 2006, 01:05 AM   #15
if youre a computer guru...start researching resistence readings of the ait sensor, find a resistor from radio shack and install it across the 2 wires so the comp reads cold intake air temps
Old December 7th, 2006, 01:49 AM   #16
might want to be careful if you try that...if the "ait" (ACT) reads too cold of a temp, it'll pull out 2 degrees of timing at least. if the ACT reads too hot it will lean the mixture out. there's some good middle ground to work with though, that won't affect timing and will enrichen the fuel mixture.
89 GT t5 3.73
www.my5oh.com/
Old December 7th, 2006, 08:27 PM   #17
what about just unplugging the o2's
Old December 7th, 2006, 09:51 PM   #18
yep that'll work, thats what i do. be safe though and keep fuel pressure above 38psi. you don't want to run lean. also if you just disconnect the o2s from the harness, leaving them in your exhaust will ruin them since the o2's heater won't burn excess fuel off of them and they will get clogged. best idea is to get plugs for the o2 holes, and put your o2s in a box or something to keep them in good condition.
89 GT t5 3.73
www.my5oh.com/
Old December 7th, 2006, 10:28 PM   #19
NO O2"s
ok, unplug the O2's , and put in box, i have my fuel set at 42 right now.
why would just unplugging the O2 make it run lean ? you said set fuel above 38 ?
I will put some type of plug in the O2 holes. So this should make it run rich all the time right ?
thanks
Old December 7th, 2006, 11:10 PM   #20
Re: NO O2"s
thanks
yes rich always at 42psi...assuming you reset the computer by disconnecting the battery for 10-15 minutes...otherwise it'll still remember the 42 psi from before you disconnected the o2s. that is, unless you upped the fuel pressure after removing the o2s. BTW, just unplugging the o2s won't make it run lean, i was just meaning that you shouldn't lower the pressure afterwards, otherwise...
89 GT t5 3.73
www.my5oh.com/
Threads Similar to: car lean..need to trick it to run rich
lean really lean plaese help 331 stroker stangzilla 331 94-95 8 January 30th, 2010 07:58 PM
lean patwrecked 5.0 Mustangs 4 September 10th, 2007 10:59 PM
Lean! Clayhistorian V6 Mustangs 5 April 24th, 2007 12:07 PM
Fuel Problems Burning Rich / Burning Lean Steves LX 5.0 Mustangs 5 March 21st, 2007 10:46 PM
Difference between running rich/lean 1996gt 96-98 3 January 29th, 2007 04:30 PM
