Need Help My belt keeps destroying its self
Old September 3rd, 2008, 12:01 PM   #1
White 89 is infamous around these parts
I noticed the other day my belt was all shredded on one edge. So I replaced it. The new belt only lasted a week and it now is all shredded too. I don't know why it is doing this.
Also when I buy a belt they keep telling me their are two different lenghts.
One is for factory AC then other is for Dealer ac. One of them is 3 inches longer. I believe I have the shorter belt on the car now.
Any idea's. I can't drive my car right now and I really need it.
1989 mustang GT 5.0
Old September 3rd, 2008, 12:07 PM   #2
2009 ROTY
AzSonicSnake's Avatar
2003 SVT Cobra
11.07@127
AzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud of
Send a message via AIM to AzSonicSnake Send a message via MSN to AzSonicSnake
sounds like either you have something on a pulley, or maybe even a bent pulley imo...
MM Cobra Club #25 My Autolog Profile
Old September 3rd, 2008, 12:26 PM   #3
I do notice the crank pully wobbling a bit. But how did it all at once start to wobble.
I don't get it.
What about the different lenght belts.
Also my water pump pully looks funny aswell. It's like it's crooked too. I have no idea what to do.
1989 mustang GT 5.0
Old September 3rd, 2008, 12:30 PM   #4
Skirt Chasing Philanderer
1FastFox's Avatar
Kit Car/Ducati/Explorer
Nike Fast
1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future
Yeah, sounds like a pully alignment issue. I would think if it was because of the wobbling it would wear out both sides of the belt from it getting tossed back and forth.
Might want to consider writing down what is said above, it will help you at some point or another in your life!
Old September 3rd, 2008, 12:35 PM   #5
just the front edge is messing up on me. Closest to the radiator.
1989 mustang GT 5.0
Old September 3rd, 2008, 02:07 PM   #6
Hunt_chevs's Avatar
2002 Gt
Not Slow
I don't get it.
thats not a good thing
Old September 3rd, 2008, 02:35 PM   #7
what does that mean? when a crank pully wobbles
1989 mustang GT 5.0
Old September 3rd, 2008, 02:42 PM   #8
5.8mustang's Avatar
1988 mustang lx
never ran down a track
5.8mustang is on a distinguished road
possibly worn out hamonic balancer or bent pully maybe even loose or missing bolts.
Old September 3rd, 2008, 02:50 PM   #9
yeah the harmonic balancer seems fishy too as it's spinning around.
1989 mustang GT 5.0
Old September 3rd, 2008, 02:57 PM   #10
5.8mustang's Avatar
1988 mustang lx
friend had a 55 chevy the harmonic balancer split and ate up the radiator big mess check it before ya run it
Old September 3rd, 2008, 03:00 PM   #11
yeah the car is parked right now and it aint going anywhere till this problem is fixed.
I didn't drive it today and I already miss the car.
1989 mustang GT 5.0
Old September 3rd, 2008, 04:28 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You have a pulley alignment issue or a burr on one of the pulleys.
Old September 3rd, 2008, 04:33 PM   #13
how did it get out of alignment. Car has been fine. I noticed the belt was bad last week. I replaced it and now a week later it's bad again.
I do notice the water pump pulley looks crooked. I put a wrench on the bolts and they were tight. But the actual water pump pulley looks a bit crooked. could this mean the water pump shaft is bad.
I replaced that water pump in the winter time. I think it was late december.
1989 mustang GT 5.0
Old September 3rd, 2008, 04:38 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Broken pulley, broken bracket, loose bolts, bent water pump shaft, etc.
Old September 3rd, 2008, 04:41 PM   #15
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
That could account for the belt running off toward the front or rear causing it to wear. When you remove the belt, check for play in the water pump shaft. Normally they start to leak alittle coolant when the shaft bearing goes.
Never fast enough.
Old September 3rd, 2008, 04:43 PM   #16
i hope I don't have to replace the water pump again. I just replaced it in the winter time. It sucked and I never want to replace a water pump again. I'd rather replace the heater core.
1989 mustang GT 5.0
Old September 3rd, 2008, 04:44 PM   #17
so no one know about the different length belts.
Why do they keep asking me is it dealer A/C or factory A/C. their are two different length belts.
1989 mustang GT 5.0
Old September 4th, 2008, 11:12 AM   #18
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
Typical auto parts store thing. No brains, just what the computer can tell them. I would venture a guess that at least 99% if not more are factory installs, that would be my default answer to that question. That really does not relate to your belt wear issue.
Never fast enough.
Old September 4th, 2008, 11:21 AM   #19
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
They keep asking you so they can get you the correct belt. You either have factory or dealer A/C or no A/C, all of which take a different belt.
Old September 4th, 2008, 12:18 PM   #20
BlownSmoke's Avatar
1991 Blown Foxbody
11.49@ 120
BlownSmoke is on a distinguished road
I'm with you sounds like a lot of BS. I would say if you are running the smaller and it isn't screeching when you start the car up you are safe to use what you have. As Far as the pulleys go it sounds like you have a bur and a wobble. or just a burr and something stained on your pulley giving it the illusion that it is wobbling.
Ponies are meant to run wild
Bowties are for business dinners
Threads Similar to: Need Help My belt keeps destroying its self
Destroying Dyno Myths... 56K Beware! 1slo5.0 5.0 Mustangs 59 February 20th, 2011 11:47 PM
Who Wants A Destroying Stroker Myths Sticky! e3sean 5.0 Mustangs 59 January 24th, 2008 06:45 PM
Terminator destroying modded srt-4 PureVolume707 Videos 12 March 27th, 2007 08:32 PM
Destroying A Myth, Backpreasure Sa-WaitNoMustang900Turbo General Tech 30 November 11th, 2006 06:42 AM
what belt? Drgnracin72 General Tech 0 June 23rd, 2006 03:58 AM
