car trouble need help!
Old November 30th, 2006, 12:25 PM   #1
Look Ma! My First Post!
5.0tangman is on a distinguished road
I have a 86' mustang body with all of the runing gear out of a 90' modle in it. I just rebuilt the motor in it not to long ago and it ran for a litle while. Then the fuel pump went out and it ran for a litle while longer I've been messing with it a while. It will run for abought 15 minutes and then cut off. Then if I take a test light and put on the negative side of the battary and touch one of the wires going into the ignition module a few times it will crank back up and run for abought 15 more minutes. When I touch the test light to the wire on the ignition module something in the disributer will click. I've had the ignition module tested so I know it is good. The car while cut off when driving it and siting still.
Old November 30th, 2006, 12:31 PM   #2
OTreborO is on a distinguished road
Re: car trouble need help!
modle
litle
abought
battary
disributer
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
Old November 30th, 2006, 12:36 PM   #3
TENGRAM is on a distinguished road
really sounds alot like a faulty/shorted ignition switch, since you say it cuts off while driving. hard to say for sure but its a $12 part if you want to try it.
89 GT t5 3.73
www.my5oh.com/
Old November 30th, 2006, 04:33 PM   #4
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Are you getting injector pulse when this condition is present?
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Threads Similar to: car trouble need help!
Got in a little trouble 98mustang V6 Mustangs 9 February 10th, 2010 12:56 AM
A Little Trouble.... nextlife 99-04 11 November 12th, 2007 03:37 PM
SCT trouble AndrewA. 99-04 3 August 24th, 2007 09:10 PM
how much trouble can you get in? MenaceToSociety The Clubhouse 20 January 16th, 2007 05:30 PM
Ran Into Some Trouble... Luvdmustang V6 Mustangs 89 November 17th, 2006 03:15 AM
