strange rpm drops?
LinkBack (1) Thread Tools
Old September 3rd, 2008, 01:17 PM   1 links from elsewhere to this Post. Click to view. #1
rusty2407's Avatar
1991 Ford Mustang LX
rusty2407 is on a distinguished road
strange rpm drops?
when im accelerating my rpms will without notice drop, and cause the entire vehicle to shudder. I have replaced the tps, and the cap and rotor, and checked the plugs. I also checked the ohms on ignition coil and it read between 7-8 which is what my friends reads and his works fine so I dont think this is the problem. If anyone knows what it could be please help.
BBK CAI and Shorty Headers, Cobra Upper/Lower Intake, Walbro 110, 24# Injectors, larger throttle body, maf, Drilled and slotted front rotors, King Cobra clutch, Cobra wheels w/ sumitomo tires, flowmasters
Old September 6th, 2008, 06:52 PM   #2
rusty2407's Avatar
nobody?
Old September 6th, 2008, 06:54 PM   #3
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
Breakout is a jewel in the roughBreakout is a jewel in the roughBreakout is a jewel in the rough
Send a message via AIM to Breakout
MAF? You make that angry and it'll do that to you.
Old September 6th, 2008, 09:09 PM   #4
Hunt_chevs's Avatar
2002 Gt
Not Slow
yea, clean the maf with throttle body cleaner, check game after that
Old September 7th, 2008, 02:11 AM   #5
rusty2407's Avatar
thanks ill do that tm and let you know
Old September 12th, 2008, 04:42 AM   #6
rusty2407's Avatar
not the maf
Old September 12th, 2008, 04:44 AM   #7
rusty2407's Avatar
i should add its not neccessarily on acceleration. if im sitting at a light, i can hold the rpms at any give rpm and it will randomly "misfire" for lack of a better word to describe it.
Old September 12th, 2008, 05:10 AM   #8
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
my car dodes the same thing when i get into the higher rpms and i dont know why....
Old September 12th, 2008, 12:23 PM   #9
rusty2407's Avatar
ya but mine is throughout the entire rpm range, i cant even drive it its so bad
Old September 12th, 2008, 01:15 PM   #10
Bigfatts's Avatar
Badass Mother 3000
Twice as fast as your ass!
Bigfatts is on a distinguished road
Sounds like a spark problem. Check to make sure none of your plug wires are grounding. How old are they? Check your distributor cap for cracks or other problems. If it looks iffy, replace the cap and rotor. When my car did this it turned out to be the distributor going bad. The magnetic pickup inside it had come loose and was rattling around. It started occasionally and progressively got worse. Couldn't tell it to look at it while it was in the car but as soon as we got it out the pickup fell out.
Old September 12th, 2008, 04:04 PM   #11
1989Gt.'s Avatar
1989 Mustang GT
for some reason i think its my trans... cause it doesnt seem to be shifting .... like its suppose to or its just misfireing i cant tell....
my plugs and wires are brand new.... i know its not them
Old September 12th, 2008, 04:16 PM   #12
Hunt_chevs's Avatar
2002 Gt
Not Slow
bad icm?
Old September 13th, 2008, 12:05 AM   #13
Bigfatts's Avatar
Badass Mother 3000
The trans wouldn't make the rpms drop while driving. If anything, if the transmission was slipping it would make the rpms spike. You say it isn't shifting right, what's it doing? Do the rpms just keep raising past where it would normally shift or what?
Old September 13th, 2008, 06:01 AM   #14
1989Gt.'s Avatar
1989 Mustang GT
oh yeah that does make sense dude no its dropping.... whats
icm?
Old September 13th, 2008, 09:03 AM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by rusty2407 View Post
not the maf
Did you test it? A real simple test is to start the car and let it idle. Then tap the MAF with the palm of your hand or even the butt of a small hammer. Use a little bit of force but not too much. If the wire is broken inside tapping on it will jar wire and cause the engine to stumble. If the engine does stumble then the MAF is bad.
The symptoms you are having are symptoms of a bad MAF.
Old September 13th, 2008, 09:07 AM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Well that is different from what you originally described. So it is not just a stumble on acceleration but it is a misfire at any rpm whether accelerating or not?
Old September 13th, 2008, 10:17 AM   #17
12.8@103... stock motor
11.8@113...150 shot
R0B0T can only hope to improve
strange, i was at the track last night and my car did this in third gear.
foot to the floor, rpms dropped like the car shut off, i let off the gas and got back in it, worked fine.
Old September 13th, 2008, 10:53 AM   #18
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
none of your cars are throwing codes?
Old September 13th, 2008, 03:36 PM   #19
11.8@113...150 shot
my CEL bulb is out.
and nobody has an OBD 1 code reader around me.
Old September 14th, 2008, 05:28 PM   #20
rusty2407's Avatar
ya itll misfire at any rpm once the engine heats up. when its cold it doesnt seem to have a problem, and i already replaced the cap and rotor, and the plug wires look decent along with new plugs themselves. could be the distributor tho.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/87397-strange-rpm-drops.html
strange rpm drops? This thread Refback September 6th, 2008 09:25 PM
Threads Similar to: strange rpm drops?
Drops of oil Smeltzs 2005 - 2010 0 August 4th, 2008 10:45 AM
gas drops thorpedo26 The Clubhouse 6 July 18th, 2008 09:56 AM
Voltage Drops... teal89 5.0 Mustangs 3 March 31st, 2008 12:43 AM
Battery light comes on, voltmeter drops when idleing BigBlockFairlane 2.3 Mustangs 5 November 6th, 2007 08:16 PM
idle problem, I can't get it down from 1g sometimes it drops 91GRNGT 5.0 Mustangs 8 December 17th, 2006 09:24 AM
