Discussing Yay rear end noise... AGAIN in the 5.0 Mustangs Forum. alright just put 300$ into the rear axle, got a bearing kit and rebuild the ...
Old September 3rd, 2008, 07:28 PM   #1
1988 Mustang
alright just put 300$ into the rear axle, got a bearing kit and rebuild the whole axle, set backlash and pinion pre-load correctly. just over 1k miles and its making a growling noise again... wtf sorta frustrating. going to put her on jack stands and run it to see where the noise is comming from and then go from there, i hope is one of the ouside axle bearings. i did not replace my axles altho they were worn where the bearings ride, so i bout the fix for that where the bearing is moved towards the outside of the axle for a fresh riding surface.
so what do you guys think
Old September 3rd, 2008, 08:56 PM   #2
5.8mustang's Avatar
1988 mustang lx
never ran down a track
sucks
long shot but do you have rear disk brakes could be breaks
Old September 3rd, 2008, 09:18 PM   #3
FoxHoss's Avatar
02' GT
if it is worn/pitted, anything but smooth as glass where the outer bearings ride it will growl... sounds like your problem right there if axles are worn
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
'02 GT~dd
'89 LX~still in swap mode
FOR SALE: Canfeild cylinder heads 302ci 2.02-1.60 valves 54cc combustion chambers-dual vavle springs $1200
Old September 4th, 2008, 12:37 AM   #4
1988 Mustang
yeah, im going to put it on jack stands and check to see where exactly the noise is comming from. the outside bearings would be the only ones that would have done something like that tho. i used a raytech install kit with bearings and all, so all 4 inner bearings i know are pretty decent bearings, i cant beleive that one would have failed already.
fyi the noise just started after about 1k. friday she is comming back apart...
Threads Similar to: Yay rear end noise... AGAIN
rear end noise ryansgt 2005+ 15 April 18th, 2008 07:16 PM
Noise From Rear End mavssteeda Drivetrain 9 April 2nd, 2008 01:51 AM
rear end noise dirg5 Suspension 6 July 18th, 2007 11:41 AM
yay! my GT doesn't like 5k rmp launches on a stock rear end! HMUSN Modular Mustangs 26 December 16th, 2006 09:16 PM
Noise in rear end OTreborO 5.0 Mustangs 3 August 7th, 2006 05:47 PM
