engine machining next session
Old September 4th, 2008, 12:55 AM   #1
1988 Mustang
88Saleen is on a distinguished road
Send a message via AIM to 88Saleen
alright i have been pondering about what to do with my 5.0. i am getting 1600$ and have about 400 right now. so im working with about a 2k budget.
starting engine maching class next session and im tryin to figure out what to do with my car. 331... 347... or 302 and do a few odd things that need to be done ex: fuel press regulator with gauge, engine temp gauge, oil pressure gauge, fuel pump, 24# injectors with calibrated MAF, roll cage, sub frame connectors, electric fan, aluminum drive shaft, WC t-5 swap, full 3" exhaust and long tubes maybe, upgrade ignition if i have the money, and a few other odds and ends i need to finish up.
Heres what i have so far, edlebrock top end kit: cam, heads, intake. 70mm throtle body with spacer, 3.73 gears, stock AOD, off road H pipe, 2.5" exhaust with shortys, 1.6 lifters, CAI inside fender style, pullys, accel coil, intake manifold spacer, AC delete, smog delete.
what do you guys think?
Threads Similar to: engine machining next session
machining egr plate 86gter 5.0 Mustangs 3 March 24th, 2008 02:23 PM
How do you prepare for a MM session? homebrewed The Clubhouse 41 March 4th, 2008 01:51 AM
Jam Session Tony_90fox The Clubhouse 26 December 8th, 2007 11:17 AM
k here's my planned mods list for this daydreaming session MSO 2.3 Mustangs 29 June 22nd, 2007 07:14 PM
A lil vid of a recent dyno session themadgnome Videos 0 March 28th, 2007 11:31 PM
