Valve Spring Troublee!
Old September 6th, 2008, 04:03 PM   #1
tehdwarvenn's Avatar
tehdwarvenn is on a distinguished road
Send a message via AIM to tehdwarvenn
I'm doing a camshaft replacement and I am also switching out the springs and lifters. I am stuck on the springs at the moment since I cannot remove a certain piece. It is the ring around the valve locks. Here is a good picture.
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
Old September 6th, 2008, 04:05 PM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
Do you have a valve spring compressor?
Old September 6th, 2008, 04:11 PM   #3
invisa stang's Avatar
1992 mustang lx notch
invisa stang is on a distinguished road
Send a message via AIM to invisa stang
you can not remove valve springs with a socket because you have to take out the ring that holds the spring in place
[rides
1987 ford F-350 XLT Lariat 7.3L idi diesel
projects
1979 ford F-350 custom (soon to get 7.3Lidi diesel)
1992 ford mustang notch (just shell soon to get engine and drive train hopefully)
Old September 6th, 2008, 05:20 PM   #4
ok guys im not an idiot.. i said heres a picture of the ring... not hey heres a picture of what im trying to do!
yes i have a valve spring compressor. i figured it out though. tapping em down with a screwdriver works. is there an easier way?
Old September 6th, 2008, 05:45 PM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
a small screwdriver is what I use.
Old September 6th, 2008, 05:50 PM   #6
I use a socket
PeteAndersonRacing.com
Old September 6th, 2008, 07:00 PM   #7
ughhh im stuck again. how do i get the other ones? (the one on the left in the picture) they are slightly different and they dont work like the other ones do. do i tap the outer thick ring down or do i get a socket to hit just the retainer ring down? (i cant get the retainer out of the ring)
Old September 6th, 2008, 07:22 PM   #8
one of my valves slid into its little hole. its about an inch in but didnt fall in completely... how the hell do i get it out? i cant push it up through the spark plug hole. ive tried all i can think of, i even tried sucking on the hole to bring it back up but it wont budge.
will putting a q-tip in with some rtv on the end stick to it? i think it has a fine layer of oil on it.
help. i have no idea how to take heads off.
Old September 6th, 2008, 07:42 PM   #9
fogged306's Avatar
89 GT
Someone may scold me for suggesting this.
If the valve stem is still in the hole partially and is still aligned, you could probably try turning the crank pulley with a breaker bar slowly until the piston pushes it up until you can grab it and lift it all the way up. Probably not the brightest thing in the world to try, but I'm a bit of a hack sometimes and thats what I would try. Stop if you feel a bind in any way, obviously.
Old September 6th, 2008, 07:58 PM   #10
yep i turned the crank with by the pulley and i got it pushed up. THANK GOD!
i was about to cry dude haha i could stand having to take off my exhaust, plumbing and fuel delivery.
Old September 7th, 2008, 10:28 AM   #11
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Don't you have air applied to the cylinder as your removing the keeper and lock?
Never fast enough.
Old September 12th, 2008, 05:25 AM   #12
MOTOIMPAIRED's Avatar
1990 LX Coupe
MOTOIMPAIRED is on a distinguished road
If you put compressed air into the sparkplug hole of the cylinder that your working on, it will push the valve up closed and you wont have to worry about it falling..
Old September 12th, 2008, 08:20 AM   #13
5.8mustang's Avatar
1988 mustang lx
never ran down a track
5.8mustang is on a distinguished road
it works ^^^^^^
best way
Threads Similar to: Valve Spring Troublee!
V6 Camshaft and Valve Spring Walkthrough 99mustang232 V6 Mustangs 21 January 16th, 2011 03:45 PM
Valve spring cups hooligan 2.3 Mustangs 0 March 31st, 2008 12:57 PM
3v 4.6L stock valve spring lift? 05roush0090 2005 - 2010 3 March 26th, 2008 01:08 PM
Valve Spring removal acmillr 99-04 0 January 7th, 2007 10:53 AM
