engine management for turbos-->?
Old September 6th, 2008, 09:52 PM   #1
Hunt_chevs's Avatar
2002 Gt
Not Slow
whats a good comp to use for when i finish putting my kit together? ive got all piping, intercooler, and headers. I know i will need injectors, and possibly a fuel pump. but what about the computer?
Old September 6th, 2008, 10:02 PM   #2
Hunt_chevs's Avatar
2002 Gt
Not Slow
or can i just have my stock one tuned? what about a standalone?
Old September 6th, 2008, 10:45 PM   #3
Hunt_chevs's Avatar
2002 Gt
Not Slow
bacc up
Old September 6th, 2008, 10:46 PM   #4
MEMBER #334
stangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of light
Send a message via AIM to stangfreak
you're anxious for some help huh? lol!
[SIGPIC][/SIGPIC]
[SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE]
Old September 6th, 2008, 10:47 PM   #5
Hunt_chevs's Avatar
2002 Gt
Not Slow
hahaha, yea,.. im waiting on some replies so i can go out and check some
Old September 7th, 2008, 09:04 AM   #6
88stangGT is on a distinguished road
some people like diffrent things.... some use a sct chiped computer which i hcn;t heard of any downfalls.. some like the anderson pms which is a stand alone fully contrable unit. which needs tuning for anything. but tells you everything that is going on..i will be using a stock a9l computer with a 6btm box and a ford svo extender.
Old September 7th, 2008, 09:05 AM   #7
what set up are you going with.. kit? turbo? motor? injectors?
Old September 7th, 2008, 07:18 PM   #8
Hunt_chevs's Avatar
2002 Gt
Not Slow
2 garret t3/t4 turbos, 36# inj's i think, on a built mod 4.6 i beieve
Old September 7th, 2008, 08:41 PM   #9
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
That's a strange fox set up to say the least
Old September 7th, 2008, 10:18 PM   #10
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
The AEM computer is nice.
Has lots of good turbo control functions along with
built in 2 steps and "anti-lag" features and data logging
Cost $1,600, but plugs into factory wire harness.
You will not need an MSD ignition box. The AEM controls
timing even more accurate.
AEM is sensitive to timing errors with a distributor though so
I recommend you also get their EPM module with it ($300) to
replace distributor and run Corvette coilpacks.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old September 8th, 2008, 01:33 AM   #11
1987 ford mustang gt
well see when shes done
A pms is a piggy back. fast, megasquirt and aem are standalone cpu;s
347, torn apart again.
Old September 8th, 2008, 03:04 PM   #12
Hunt_chevs's Avatar
2002 Gt
Not Slow
yea, im going for something different,....
plus i like the 96-98 cobra blocks.. and the mod motor possibilities
Old September 8th, 2008, 03:06 PM   #13
Hunt_chevs's Avatar
2002 Gt
Not Slow
hrmm,.. sounds like a nice set up,.. what benefits are there from using the epm mod. with the replacement of dist. and packs?
Old September 8th, 2008, 09:17 PM   #14
EscortSportage's Avatar
1989 Mustang GT 5.0
mega squirt 2
10 point Cage
Bunch of newer mustang parts
Maximum Motorsports catalog
Sparco stuff
"a huge bad azz motor is nice untill you have to turn or stop"
Old September 8th, 2008, 09:36 PM   #15
Hunt_chevs's Avatar
2002 Gt
Not Slow
who knows where i can peep game on some of the units you all mentioned?
Old September 8th, 2008, 11:17 PM   #16
Fast
21st centruy ignition system.
more accurate timing,
more stable timing
1 coilpack for each cylinder is better than 1 coilpack for all 8 cylinders.
basically gives you a late gen new car ignition and timing
system vs. a mid '80s stock Ford one.
Nothing wrong with distributors they work fine, but there are better
and more modern ways to get timing and control spark now.
God Help Us
Old September 10th, 2008, 02:42 PM   #17
Hunt_chevs's Avatar
2002 Gt
Not Slow
more stable timing
and this would be for the modular im assuming?
Old September 10th, 2008, 04:59 PM   #18
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
more stable timing
This is the best advice ive seen in a long time. Although, the corvette / LS style coil packs wont be needed for a modular motor.
You wont need to purchase the EPM mod. If you have the wiring harness for the mod motor, just purchase the AEM system thats for 96-98 mustangs, or 99-04. It may be worth while to get a 99-01 cobra harness, and run the factory COP. If your wondering what "COP" means, it stands for "Coil On Plug."
The twin coil DIS system on the 96-98 Cobras works pretty well, you could stick with that aswell, and run the AEM. I havent had much time with AEM. But, i can say it works. It works so well, i have a hard time chasing down cars using it!
Old September 16th, 2008, 01:41 PM   #19
Authorized Vendor
Matt Cramer's Avatar
Matt Cramer is on a distinguished road
We're a Megasquirt seller (and also carry large injectors). We've got a basic write-up on some of the easier ways to set up Megasquirt on a Mustang (including 4.6s) here:
How to MegaSquirt your Ford Mustang
It's also possible to set up a Megasquirt for direct coil control with no EDIS module.
Old September 16th, 2008, 08:18 PM   #20
Hunt_chevs's Avatar
2002 Gt
Not Slow
arite,.. so what exactly am i going to need..?
Threads Similar to: engine management for turbos-->?
anger management BWAL The Clubhouse 10 May 15th, 2008 05:25 PM
anger management whitemustang02 The Clubhouse 24 January 16th, 2008 10:00 PM
Stand alone Engine management for 4.6 32V, need help Devilman Modular Mustangs 3 July 23rd, 2007 09:18 AM
Programmable Engine Management ?s ScrewMachine 5.0 Mustangs 2 October 17th, 2006 04:06 PM
Turbos For A Smaller Engine MSO General Tech 5 September 27th, 2006 04:43 PM
