Discussing Speed Density in the 5.0 Mustangs Forum. My '87 Coupe, has speed density, and I'm not gonna change to Mass Air. Because ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Speed Density
My '87 Coupe, has speed density, and I'm not gonna change to Mass Air. Because I'm only 16 (17 in Jan.) I'm just building a quick daily driver. I heard you can do just about anything to speed density, as long as you don't add an aftermarket camshaft, and probably make more power. Is this true?
11.47@120.58
You can get away with most stuff, the major things (like heads, cam, intake) may cause problems - however some cams, heads, etc. won't cause problems.
#3 | |
Sometimes you can do a cam swap if you keep the duration at 220* or less at .050
1982 GT (t-top) 351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's Best E.T 12.85@102mph |
1999 Ford Mustang V6
i was told that the 86 5.0 in my f150 would start having vac issues with under 114* lsa due to the speed density, if i recal correctly
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
Threads Similar to: Speed Density
| Cai for Speed Density | Drick | 5.0 Mustangs | 16 | September 19th, 2007 10:20 AM |
| speed density cam options | itsmyfiveoh | 5.0 Mustangs | 4 | May 13th, 2007 05:01 PM |
| Speed Density VS MAF | insnedrmr | 5.0 Mustangs | 7 | April 17th, 2007 10:24 PM |
| speed density with stage 2 cam | dr.gonzo | 5.0 Mustangs | 5 | March 13th, 2007 06:39 PM |
| Speed Density or MAF? | 8A_Honda | 5.0 Mustangs | 15 | February 6th, 2007 08:04 PM |
