running bad...small miss
LinkBack (1) Thread Tools
Old September 11th, 2008, 11:45 PM   1 links from elsewhere to this Post. Click to view. #1
GT87Stang's Avatar
1987 Mustang GT
GT87Stang is on a distinguished road
My mustang has been acting up here lately.. not all the time just some times it stutters pops the more gas i give it... i put a new fuel filter same thing... and the check engine light flashes sometimes... and others it just stays on... most of the time its not on.. it still messes up even when the light is off though... I can turn the switch off and back on and it seems to run better... any ideas.. and its also converted to Mass Air...sorry it sounds kinda confusing...
1987 Mustang GT
World product heads
Triflow Stage 1 Cam
Parker Funnel web 650 DP
Eagle Rods with forged pistons
T5 with 373's
Old September 11th, 2008, 11:47 PM   #2
1992 Lx
11.39@119.24
run the codes
Old September 12th, 2008, 05:47 PM   #3
humbleLX's Avatar
1989 LX hatch
humbleLX is on a distinguished road
sounds like an ignition problem. try check the codes first, might just be a bad tfi. good luck
GT40 crate Ecam 1.7RR GT40X alum head GT40 P1SC 12rib IC 12 psi 42inj AFM PMS IV PMAS 3" Flotube BBK 70mm TB 255 Walbro short hdr BBK o/r X, 2ch Flows, way too much to list... if it ain't blown, it sucks...
Black & Tan
Old September 13th, 2008, 05:40 AM   #4
GT87Stang's Avatar
1987 Mustang GT
my check engine light isn't always on... its off most of the time... will it sill pull codes with it off?
1987 Mustang GT
World product heads
Triflow Stage 1 Cam
T5 with 373's
Old September 13th, 2008, 09:09 AM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/88623-running-bad-small-miss.html
running bad...small miss This thread Refback September 13th, 2008 09:31 AM
Threads Similar to: running bad...small miss
Help Car Running Bad Stang281GT 99-04 4 May 15th, 2008 11:51 PM
Bad miss at WOT, Need Help!!!!! kilby91 5.0 Mustangs 13 January 19th, 2008 06:46 PM
Bad running... alabamastanger 5.0 Mustangs 4 July 15th, 2007 06:25 PM
Help w/ why my GT might be running bad Goose 07 2005 - 2010 7 March 23rd, 2007 08:51 AM
Help Needed (Running Bad) wraitherx 5.0 Mustangs 19 November 16th, 2006 11:12 PM
