5 lug conversion
Old December 2nd, 2006, 05:09 PM   #1
92_fox's Avatar
92_fox is on a distinguished road
5 lug conversion
i know for the rear i use the driver side axle out of a 92 ranger and then the drums but for the front i dont know what car i would the rotors off of i know its a lincoln but i cant rember what year and model
92lx, bbk hpipe, flowmaster cat back, underdrive pulleys, bbk cai, msd pro billit dizzy and more to defff come
Old December 2nd, 2006, 09:14 PM   #2
doorvip is on a distinguished road
87-91 mark vii rotor but you will be limited to your wheels because the hub sticks out so far so you may not be able to put on center caps I used spindles hubs rotors and calipers off a 94-95 and you just need a small spacer or washers for the ball joint because the threads are a little longer or put a 94-95 ball joint in your 87-93 hope this helped
Old December 3rd, 2006, 04:02 AM   #3
86er's Avatar
I thought you had to use an older like 89 ranger drum, the 92 is gonna have too big of a diameter i thought
Just a truck
Old December 3rd, 2006, 02:16 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
85-91 Lincoln Mark VII and 84-86 SVO rotors
'83-'92 4 cylinder/3.0 V6 Ranger/Bronco II left (driver) side axle or '86-'97 Aerostar right (passenger) side axles and drums
Old December 3rd, 2006, 05:13 PM   #5
Darrellx14's Avatar
Darrellx14 is on a distinguished road
you can use the axles out of an SVO too and have rear disc brakes as well right?
Old December 3rd, 2006, 07:32 PM   #6
92_fox's Avatar
ok thanks for the help gonna call some junkyards tomorrow on the drums and axles and then the local parts store for the rotors
Old December 3rd, 2006, 10:54 PM   #7
Mr_Evil's Avatar
Mr_Evil is on a distinguished road
My Mustang has the same conversion done. I have been looking for drilled and/or slotted rotors. Anyone know where I can get some? I can find the SVO rotors. But no Mach V rear rotors.
Old December 4th, 2006, 01:04 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No, you would need the entire axle assembly. The axle shafts are longer than other Mustangs.
Old December 4th, 2006, 04:10 PM   #9
92_fox's Avatar
my friend might be giving me his rear out of his 96 i know its a little wider if i use his wheels will it fit without hitting the fenders and will i have to change my master cylinder since its disk
Old December 5th, 2006, 07:52 PM   #10
92_fox's Avatar
nobody? i need help with this if im getting it it will be this weekend im doing the swap and this is my daily driver so i need brakes so this way if i have to change the master cylinder or whatever i need ill order it so i can get it done
srry if im being a pain in the ass
Threads Similar to: 5 lug conversion
2v to 3v conversion??? droppedbass87 96-98 26 September 18th, 2010 01:08 AM
conversion Mustang RacR94 99-04 8 April 2nd, 2007 11:02 PM
2.3L to 5.0L conversion stan_doe 5.0 Mustangs 6 January 23rd, 2007 01:39 AM
99-04 V6 To GT Conversion ?'s ineedajob V6 Mustangs 7 November 9th, 2006 04:18 PM
After A 5 Lug Conversion... 347tt 5.0 Mustangs 7 September 28th, 2006 03:53 PM
